Old 02-24-2013, 08:32 PM   #1
cst204x4
4x4 frame holes
I have a 1969 3/4 ton 4x4 frame I am converting from stick to 350/350/205 auto and the holes in the frame are not there as they did not put autos in 4x4 that year. Does anybody have a 70-72 frame they can take detailed pics of to correctly locate the holes for the transfercase crossmember. thanks
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 02-24-2013, 10:07 PM   #2
obijuan
Re: 4x4 frame holes
just install the trans and adapter and slap the crossmember up there. center it up and bam.
obijuan is offline   Reply With Quote
Old 02-25-2013, 02:32 AM   #3
andrewmp6
Re: 4x4 frame holes
Obijuan is right jack it up where it should be mark the holes drill them and bolt it in.
andrewmp6 is offline   Reply With Quote
Old 02-25-2013, 08:02 AM   #4
jjzepplin
jjzepplin's Avatar
Re: 4x4 frame holes
I took the rivets out of the brackets that go to the top rail and removed them from the transfer case member. This makes it much easier to install and remove. Just replace the rivets later with grade 8 bolts. Those top rail holes are a beotch to drill out and get right. Not sure if they are really necessary as I have run without them on my Blazer for quite some time.(went thru the Rubicon without them) I think the only way to drill them is a very long bit going through the bottom holes to the top using the bracket as a guide. But yeah...just drill-em.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Thread Tools
Display Modes
