Old 02-27-2013, 10:36 PM   #1
joeydirt
Anyone recognize these wheels
Im trying to find a center cap that works with them and clears the c20 rear hub, they have no stamp on them Im thinking they were oem options
thanks
joeydirt is offline   Reply With Quote
Old 02-27-2013, 10:40 PM   #2
Hx16457
Hx16457's Avatar
Re: Anyone recognize these wheels
You might get the tire removed and check the wheel. They have model numbers on them!
Or you could measure the inside diameter and order some that will match that dimension!
Good luck!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 02-28-2013, 01:16 AM   #3
slepysal
slepysal's Avatar
looks like a pacer 162M aluminum mod. I'm pretty sure a push through cap will work. Were are you located?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-28-2013, 01:46 AM   #4
gixxer711
def not a factory wheel. most aftermarket wheels do not have the manufacturer's name or part number on the back of the wheel and just about every wheel manufacturer has made a style similar to that over the years. looks like it should take a push thru cap like mentioned. the wheel is likely a 130mm gore which is pretty typical for 8 lug wheels. wheel stores hate screwing with center caps, so your best bet is to call around to your local wheel shops and ask for an 8 lug push thru short cap in stock, then take a wheel off your truck up there and slide the cap thru to see if it fits. i mention the short cap because you do not have a long hub that sticks thru the wheel and a long cap would look crappy.
gixxer711 is offline   Reply With Quote
Old 02-28-2013, 07:28 AM   #5
joeydirt
Well I wanted to run them on my 66c20 so there is a big ass hub in the rear
Old 02-28-2013, 07:45 AM   #6
tincan1966
tincan1966's Avatar
there's too many lug nut holes for a C-10
tincan1966 is offline   Reply With Quote
Old 02-28-2013, 07:47 AM   #7
joeydirt
There sure is I made a typo its a c20
Old 02-28-2013, 11:11 AM   #8
vpersh
vpersh's Avatar
They look like the Outlaw II wheels I have on my truck - or a variation thereof....
I bought mine locally.
Van Pershing
Tucson, Arizona
Idea Page
vpersh is offline   Reply With Quote
Old 02-28-2013, 11:26 AM   #9
slepysal
slepysal's Avatar
Just go to your local tire/ wheel store and ask for 8 lug tall push thru caps
5.11" diameter and 6.33" tall.
I asked were you were located to see if I could recomemd a shop..... let me know
Old 02-28-2013, 12:06 PM   #10
PAPA KENT
PAPA KENT's Avatar
there a outlaw II design.any aftermarket cap will fit them.
PAPA KENT is offline   Reply With Quote
Thread Tools
Display Modes
