Old 03-01-2013, 04:05 PM   #1
ZombieWeinerDog
ZombieWeinerDog's Avatar
A few questions about static drops.
Right now my truck is dropped pretty low. the only problem is i cant remember how low it is. is there a way to measure how low ive dropped? also. i think i have drop spindles and i know i have drop springs in the front and drop springs in the rear. as far as i can remember i dropped it 5 in the rear and a total of 4.5 in the front, is there anything else i need for a correct drop? my carrier bearing breaks constantly so i know i need a one piece driveshaft or a slip yolk or something. will an adjustable tracking arm fix this too? ive read about the shock relocation kits, will this help? the main problem is in the front. i cant remember off the top of my head what tires in running, but there is maybe and inch and of clearance between the bump stops and i still have a large gap in between the fender and the tire. Picture here: http://i.imgur.com/fM85VY3.jpg
I have larger tires in the rear, and that looks pretty good, but when i see other pictures of dropped trucks, they always look lower than mine. as far as i know i have 2.5 inch drop spindles in the front with 2 inch drop springs, but i didnt buy the parts or install them ( i installed the drop springs, but not the spindles.) the truck is also in storage right now for the winter and i have not been able to confirm if they are in fact drop spindles. i will check to make sure soon though. any advice?
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 03-01-2013, 04:26 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: A few questions about static drops.
If your driveshaft is the correct length and has been ballanced it should last 40 years.
Lowering your truck can make the rear driveshaft too long and push the bearing through the bracket.
These 2 piece drivelines can be put together VERY wrong. And even when they are put together correctly any maintanence will effect the ballance and the shaft needs to be reballanced.
Take your driveshaft to a driveshaft shop with measurements of your truck at ride height. Tailshaft to center of carrier bearing mount, center of carrier bearing mount to center of rear ujoint. And have them ballance the shaft.
Or if your shaft needs a bunch of work spend the $200 on a new one piece reusing your trans yoke.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-01-2013, 05:40 PM   #3
cdowns
cdowns's Avatar
adjustable panhard bar /// allows rearend to b centered in the frame
shock relocators /// allows optimum angle for shocks to work at the most effective and comfortable rate
Old 03-02-2013, 02:44 AM   #4
ZombieWeinerDog
anyone have advice on how to properly gauge the drop? does the picture look like a 4.5/5 inch drop?
1972 longbed- 454
1967 shortbed- 355
Old 03-02-2013, 11:54 PM   #5
ZombieWeinerDog
bump
1972 longbed- 454
1967 shortbed- 355
Old 03-03-2013, 12:15 AM   #6
brad_man_72
the boat guy
I think lmc has measurements from axle centerline to top of wheel opening in their catalog.
Nope just a drawing showing stock and different drops.
Thread Tools
Display Modes
