Old 03-04-2013, 08:02 PM   #1
Hotrob72
Hotrob72's Avatar
What headers to use Dropped truck
Working on my sons 1969 C10 327 t-400
The truck is lowered and when we pulled the engine it was running full length headers which hang to low. What mid length headers are you using on dropped trucks, other then the 400 sandersons ? Do I have any other choice?
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline   Reply With Quote
Old 03-04-2013, 08:08 PM   #2
Gmcfolife
Gmcfolife's Avatar
Re: What headers to use Dropped truck
Here are the ones I purchased. They are made by Sanderson headers.
http://www.earlyclassic.com/catalog....d+upgrade+kits
Gmcfolife is offline   Reply With Quote
Old 03-04-2013, 08:10 PM   #3
Gmcfolife
Gmcfolife's Avatar
Sorry link didn't work. Early Classics sells them. Just look under headers.
Old 03-04-2013, 08:11 PM   #4
Gmcfolife
Gmcfolife's Avatar
Not sure if there the 400's
Old 03-04-2013, 09:08 PM   #5
buckskins4ever
buckskins4ever's Avatar
Other than a long tube (which is going to hang beneath the frame a bit) you will need to do shorties get a good exhaust guy to weld up you a nice 3 inch crossover right behind the tranny.
I can drop mine almost all the way down with Hooker Long Tubes
buckskins4ever is offline   Reply With Quote
Old 03-04-2013, 09:11 PM   #6
Hotrob72
Hotrob72's Avatar
Yes I am aware of the sandersons, thought maybe someone else with a dropped truck has used something else.
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
Old 03-04-2013, 10:40 PM   #7
1low
Headman mid length headers for chevelle work awesome I got the part # off this site u can search it then buy tubular motor mount towers to clear them
1low is offline   Reply With Quote
Old 03-04-2013, 11:15 PM   #8
cubber
Hedman #69010. New ones made specifically for our trucks, $200 from Jegs, fit great on my bagged 69.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 03-04-2013, 11:24 PM   #9
HotRod C/10
HotRod C/10's Avatar
What heads are you running on the 383?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-04-2013, 11:29 PM   #10
70cst
70cst's Avatar
When I had headers...these are what I used....
http://dougthorleyheaders.com/
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-04-2013, 11:32 PM   #11
HotRod C/10
im running GMPP FastBurn heads, finding a header that fits them and the truck is a bit tricky
LS SWAPPED
-1976 SILVERADO
Old 03-05-2013, 12:43 AM   #12
cstm68
cstm68's Avatar
anyone know what will work with a manual trans? i cant find anything to clear the clutch linkage
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 03-05-2013, 12:48 AM   #13
oldschool18
oldschool18's Avatar
I think mine where camaro shorty headers from headman
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 03-05-2013, 12:53 AM   #14
Square_78
Square_78's Avatar
Mine are 69 camaro shorties from Flowtech. Cheap. $140.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 03-05-2013, 08:22 AM   #15
I've never run any full length headers that hang below the frame...at least not the straight and lowest part of the frame. Headers for a manual trans are a mystery. I see this asked and never a definitive answer. I've had headers fit with clutch linkage and never gave it a thought,but don't recall exactly what they were. I can say,what you look for is the rear tube on the driver side has to drop straight down if not slightly forward to clear the z-bar. I've had them run directly through (under the z-bar) where the lower arm is. I had to cut the arm off and relocate to one side.
Old 03-05-2013, 12:29 PM   #16
Hart_Rod
Hart_Rod's Avatar
These work really well:
http://67-72chevytrucks.com/vboard/s...d.php?t=562386
Hart_Rod is offline   Reply With Quote
Old 03-05-2013, 01:39 PM   #17
Hotrob72
Hotrob72's Avatar
Originally Posted by Hart_Rod View Post
Yep, those are some real nice headers............
Although was hoping for something in the under 200 range. Thanks to those that have responded.
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
Old 03-05-2013, 10:40 PM   #18
cstm68
cstm68's Avatar
do the camaro headers work with a clutch?
Old 03-06-2013, 01:00 AM   #19
cubber
They're old 441 heads that have been "opened up" a little
=MATTHEW
Old 03-06-2013, 09:48 AM   #20
No. None of the 3/4 length/car type headers work with manual trans. The run right through that area. You need headers with the rear tube that runs straight down or slightly forward. Anything that angles back will run right into the clutch linkage. They need to drop down,then run under the linkage to work
Thread Tools
Display Modes
