Old 03-06-2013, 01:53 AM   #1
vegadesign
vegadesign's Avatar
Exclamation Carrier bearing question/ bagged
I haven't come across this before
When a bagged c10 with a two piece driveshaft drives when fairly aired out,
Does the carrier bearing need to be raised to decrease the amount of angle on the drive shaft
Mine started smoking on me by the time I got to the corner from my house
This is how low I was driving
Possible seized bearing?
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 03-06-2013, 03:40 AM   #2
Square_78
Square_78's Avatar
Re: Carrier bearing question/ bagged
Normally to fix the pinion angle from such an extreme drop, you would need to raise the bearing. You can just knock out the rivets, flip it over and bolt it through the existing top holes. I dont know why yours would be smoking though, buy yes its probably seized. When I lowered my 78 c10, my u-joints were binding up and making a banging sound as I was driving. I added some shims and its fine now.
What happens if you lift it up and drive it?
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 03-06-2013, 11:55 AM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
If you replace the bearing the shaft will need to be reballanced. May as well take it to the driveline shop right off the bat so they can tell if your 40 year Old parts are worth reusing. Best case scenerio 3 ujoints, carrier and a ballance.
You may want to take measurements from trans output to center of carrier mount then center of carrier mount to center of rear ujoint at different ride heights. You may need a slip and stub in your rear shaft.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Thread Tools
Display Modes
