Old 03-08-2013, 10:12 PM   #1
SuperSub
SuperSub's Avatar
My First Try At An Interior Project!
Well, I have undertaken another project on the SuperSub. If you are anything like me, you handle upgrades in bite size pieces as you have the time and money to do them. Unfortunately, I seem to always be short of time and money, so I end up having to handle upgrades on my own instead of dropping my ride off at a shop. My latest project was to try my hand at improving the interior. To this point, I have been driving around without inner door panels in the Sub. I have never done interior work, so this seemed like a good first time interior project opportunity.
I did some online research and found that JoAnn’s Fabric (a chain store) carries material that was appropriate for the job. I also learned that they would accept coupons from their competitors. I found a competitor’s coupon online that was valued at 50% any regularly priced item. I went to the store and found they had a variety of colors, textures and grades, including marine grade. The black faux leather material that I liked cost about $20 a yard. I bought two yards using the 50% off coupon. I figured that would give be enough material to complete the front and rear door panels.
I went to Home Depot and bought a thin sheet of 4’ x 8’ particleboard that I could use as a foundation for the door panels.
When I returned home I measured the area to be covered by the door panels. I cut the particleboard to fit and used a hole saw to drill the openings for the door handle and window crank shafts.
I cut the upholstery about an inch larger that the particleboard pieces that I had cut. I applied spray contact cement to the backside of the upholstery, as well as the front side of the particleboard. Once both had dried, I laid the upholstery face down on a flat surface and centered the front side of the particleboard on it. I turned the joined pieces over and used my hands to work out any wrinkles or air that may be trapped in between. I cut a series of intersecting lines in the openings for the door handle and window crank shafts. I turned the upholstered side down again and applied glue to backside of the upholstery that protruded past the edge of the panel, as well as to the edge of the particleboard. I stretched the edge of the material around to the back of the particleboard and used spring clamps to hold it in place.
I cut pieces from a roll of bubble wrap type insulating material that I already had and applied it to the backside of the door with 3M body caulking strips that I had from a past project.
I cleaned and polished the trim pieces that hold the upper part of the door panels in place. I used stainless button head screws to hold the bottom edge of the door panels in place, making sure to put some anti-seize on each of the bolts so they wouldn’t gall in place. I installed the covered panels and topped them off with new arm rests that I purchased from the Truck Shop.
Although these door panels aren’t as fancy as they would be if made by a professional shop, I was quite happy with the finished project.
SuperSub is offline   Reply With Quote
Old 03-08-2013, 10:21 PM   #2
POS1
Re: My First Try At An Interior Project!
Looks good to me!
- Brian
FleetFilter.com
1991 Chevrolet V1500 Suburban 4x4
1986 Jeep CJ7
1969 Porsche 911S Targa
POS1 is offline   Reply With Quote
Old 03-08-2013, 10:42 PM   #3
SuperSub
SuperSub's Avatar
Originally Posted by POS1 View Post
Looks good to me!
Thank you!
Old 03-08-2013, 10:52 PM   #4
vectorit
What?
vectorit's Avatar
Good job!
I did my interior side panels myself to, and I can relate to the trouble it takes to make it look good.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-08-2013, 11:06 PM   #5
flashed
Now those door panels look as nice as the outside of your rig ,good job.
flashed is offline   Reply With Quote
Old 03-08-2013, 11:07 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I don't see anything wrong with that. Looks good. Now you can take the wife/girlfriend out for a nice dinner on the money you saved...
LockDoc
Leon
Old 03-09-2013, 08:51 AM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
nice job
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-09-2013, 10:00 AM   #8
dougo
dougo's Avatar
Looks great, nice work!
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 03-09-2013, 11:56 AM   #9
kcsa75
kcsa75's Avatar
Looks good. Just an FYI, my wife is a seamstress and get's those JoAnn's coupons in the mail every week. Hancock's Fabrics -- another chain -- will accept competitors coupons as well.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 03-09-2013, 03:07 PM   #10
SuperSub
SuperSub's Avatar
Thanks to all those who provided feedback. I hope to undertake making matching panels for the rear section and the barn doors soon. I am trying to come up with a design for the rear section that will include molded boxes for speakers.
Old 03-09-2013, 03:09 PM   #11
SuperSub
SuperSub's Avatar
Good to know, thanks. Have you been able to talk your wife into helping with interior work on your rig?
Old 03-09-2013, 03:10 PM   #12
SuperSub
SuperSub's Avatar
LockDoc
That sounds like a plan that my wife would agree with. Thanks
Old 03-12-2013, 02:20 PM   #13
4shongo
Nice job!!
4shongo is offline   Reply With Quote
Old 03-22-2013, 12:01 PM   #14
PAWS 72
PAWS 72's Avatar
Good looking panels.I may do that to my 71 when the time comes.
PAWS 72 is offline   Reply With Quote
Old 03-23-2013, 11:36 PM   #15
70cst
70cst's Avatar
1st Class
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-24-2013, 12:06 AM   #16
SuperSub
SuperSub's Avatar
Thank you all for the kind words.
Thread Tools
Display Modes
