Old 03-10-2013, 07:51 PM   #1
Fantom
Fantom's Avatar
Rear end spongy after 4 / 5 static drop
I lowered my '71 LWB using 2" drop spindles & springs up front and 5" drop coils in the rear. I relocated the rear shocks and also installed the short shocks. The back is real bouncy, and when I drive down a rough road it almost feels like it's bouncing side to side as well.
I love the look, but hate the ride.
Has anyone else had this problem?
Will replacing the springs with bags stop this?
Thanks,
Kevin
Fantom is offline   Reply With Quote
Old 03-10-2013, 07:52 PM   #2
Fantom
Fantom's Avatar
Re: Rear end spongy after 4 / 5 static drop
I know everyone loves pic, so....
Old 03-11-2013, 01:07 PM   #3
Hart_Rod
Hart_Rod's Avatar
Who's lowering kit? It seems that the CPP springs are "spongier" than the ECE ones that have purchased (at least in my experience).
Hart_Rod is offline   Reply With Quote
Old 03-11-2013, 01:32 PM   #4
oldman3
oldman3's Avatar
fantom, I had the same problem with a friends 67 LWB step side. I posted a thread #463544 about the problem. Since then I have changed the rear springs to what CPP called a 4"drop heavy duty spring. Didn't make any difference. We also changed the angle a little more on the shocks (more upright), no difference. The owner hasn't had time to work with me on more stuff, so it's still the same. Next things I wanted to check are angles on the pinion, two piece drive shaft, etc. If you can, read over my post and check out the pics, then post back here any more questions. Between that and your post maybe we can come up with a fix...Jim
oldman3 is offline   Reply With Quote
Old 03-11-2013, 01:48 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
What brand shocks?
Keith
Convert to disc brakes.
Old 03-11-2013, 09:57 PM   #6
clemsonteg
What about the track bar?
clemsonteg is offline   Reply With Quote
Old 03-12-2013, 12:36 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
I've seen the relocators for the shocks put on backwards...got a pic of them installed?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-12-2013, 12:37 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
To me it sounds like your track bar may be running up hill
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-12-2013, 05:54 PM   #9
Fantom
Fantom's Avatar
Thanks for the replies. I feel real stupid now, because I figured out what the problem was.... I had the rear shocks on upside down. Flipped them over and problem solved.
Old 03-12-2013, 05:57 PM   #10
Fantom
Fantom's Avatar
I hope your fix will be as easy as mine.
Old 03-12-2013, 06:36 PM   #11
oldman3
oldman3's Avatar
Fantom, glad you fix was that easy. My shocks are on correct, hopefully within the next few weeks I can get with the owner, takes some more pics of track bar, springs, and check the pinion angle and then post up another thread for help from the suspension guys. I posted my first thread in the general area, got some info but didn't help with the problem...Jim
Old 03-18-2013, 12:16 PM   #12
Gmforce
Gmforce's Avatar
the panhard bar lenght and angle can affect this greatly as well ....fyi..
Gmforce is offline   Reply With Quote
Thread Tools
Display Modes
