Old 03-10-2013, 08:47 PM   #1
C10TN
C10TN's Avatar
Fuel Gauge Is Whacked Out... Any Ideas?
The fuel gauge on my 66 is acting goofy. (Tank behind the seat.) Any idea what the problem is or at least where I should start?
http://youtu.be/m9kWuczp5nQ
Check out my BLOG to learn more about my truck project: CLICK HERE
C10TN is offline   Reply With Quote
Old 03-10-2013, 08:53 PM   #2
akaupp
Re: Fuel Gauge Is Whacked Out... Any Ideas?
I wonder if it has anything to do with the radio, almost seemed to go with the voice.
akaupp is offline   Reply With Quote
Old 03-10-2013, 09:19 PM   #3
Divine 59
Check your ground. If I recall most gauges work on electric resistance. So you are not getting a steady reading. I would try cleaning the ground attachment real well. Next would be to check for any broken insulation. If the wire is moving around it could be intermittently contacting a metal source and grounding out. I would also check it with a multimeter. You may discover the voltage reading to the gauge is "all over the place" causing the needle to bounce. Last thing I would check is your fuel gauge. check the windings and the posts. Good luck. I had a gauge do this on my 59. One of the posts were loose.
Divine 59 is offline   Reply With Quote
Thread Tools
Display Modes
