Old 03-11-2013, 07:18 AM   #1
kgmunro
Control arm clearance
Hi guys I have a question. I have a 65 gmc 1/2 ton, and I put a 3 inch drop spindle on the front. I mounted my 15x8 steel factory rally wheels and they seem to just rub the front tip of the lower control arm. Has anyone had this issue? What should I try? Wheel spacers? How about shaving the lip on the lca...will that weaken it?
kgmunro is offline   Reply With Quote
Old 03-11-2013, 08:00 AM   #2
Realnoisy
Realnoisy's Avatar
Re: Control arm clearance
Mine rubbed on the spindle and I had to grind some off the spindle. As for the LCA, I don't think shaving a little will weaken it. Can you post a photo of it?
A spirit with a vision is a dream with a mission - Neil Peart RUSH
Realnoisy is offline   Reply With Quote
Old 03-11-2013, 08:04 AM   #3
nibulus
nibulus's Avatar
I have exactly the same clearance issue.
There doesn't seem to be many more alternatives than the ones you mentioned:
i) wheel spacers
ii) wheels with less offset
iii) modifying the lower arm itself
iv) modifying the spindle
I'll probably go for i) or iv). Haven't decided yet. Wheel spacers are obviously a fairly simple solution, but, depending on the spacer thickness/offset of the wheels/tire size, it might cause a clearance issue at the fender...
nibulus is offline   Reply With Quote
Thread Tools
Display Modes
