Custom back spacing
What would be the optimal backspacing for 18x8 front and 18x10 wheels on a 72 with the wide rear? Assuming the truck is 4/6 dropped with ECE Kit.
I am curious if anyone would deviate from the normal acceptable off the shelf specs if a totally custom backspace is allowed. I am looking at the American Racing VN327 Rally wheels. Any help or info is greatly appreciated. I also hope these would work with McGauphy Big Breaks front and rear (13 inch rotors). Last edited by 1bad396ss; 03-15-2013 at 11:20 PM. Reason: Hit submit too early!!! |
Re: Custom back spacing
I have come up with a 4 inch backspace for the front 18x8's and 5.25 inch backspace for the rear 18x10's. If anyone has any other recommendations, I would certainly like your imput and/or pictures.
67-72 parts collector,…
![]() Join Date: Nov 2002
I like 5" bs on a 18x8 up front.
5.5" bs on a 18x10 with the wider 71-72 rearend. But that's what I like. Remember a 8" wheel will measure 9". 10" wheel will measure 11". Posted via Mobile Device
It all depends on how you want the wheels to fit on the truck. I would say a 4.75" up front, and 5.5" on the rear... But all personal preference. The McGaughys brakes don't have a lot of caliper offset, so you will be Ok there.
We are an American Racing dealer, so let me know if we can help you out further. Travis Posted via Mobile Device |
![]() Join Date: Jan 2007
It is the original rearend im assuming i believe its diff with the 67-68 rearends, they are narrower in width so im thinking 5 inch backspacing for the rear.
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. ![]() |
IF it's the original rear end, the wider 71-72, then I would run the 5.5" in the rear.
lolife99 would you happen to have pics of a 67 fleet 20x10 with 5x5 backspacing, and a 72 fleet 20x10 with 5x5.5
Do you mean narrow rearend with 5" BS and wider rearend with 5.5" BS?
Early 67-69 rearend with with 20x10 (4.75" BS)
71-72 wider rearend with a 20x10 (5.5" BS)
Here is a 20x10 with the wider rear end.
What backspace?
#13 |
Thx you sir, these look awesome.
#14 |
5.5" backspace.
#15 |
Thanks for the recommendations. I appreciate it.
Thread Tools | |
Display Modes | |
