03-16-2013, 01:27 PM | #1 |
Turbo 400 cooler line connection. Help please.
Which oil cooler line goes where from tranny to radiator? My understanding is bottom line of tranny to top of radiator. Just wanna be sure.
Posted via Mobile Device |
03-16-2013, 03:24 PM | #2 |
Re: Turbo 400 cooler line connection. Help please.
My top is going to the top, and the bottom is going to the bottom, I hope thats right. The discharge from trainy goes to bottem to make sure fluid fills the resevoir same as heater core. If not it'll flow backout without as much cooling. An airconditioning trick, opposit flow, warmer meets colder.
03-16-2013, 03:49 PM | #3 |
On a TH400 (or 350) the cooler fluid flow is: lower trans. out, lower radiator cooler in, upper radiator cooler out, upper trans. in.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thread Tools | |
Display Modes | |
