front rotors
Has anyone had there rotors drilled for the 5 on 4/3/4" car pattern? I'm supposed to take my roters to the machine shop Tuesday. I pulled them off today and, it doesn't look like enough room for the stud on the inside of the rotors. Is there any company that sells them already done? Maybe there is another application that fits and has the bolt pattern that I want. I have the heavy duty brake option by the way.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: front rotors
Other than going with aftermarket big brakes, the only way I have heard of is in this thread. But you would have to change your spindles.
http://www.67-72chevytrucks.com/vboa...d.php?t=319487 It might be easier and less $$ to just have your rotors machined and drilled. I believe in order to drill the secomd bolt pattern, the ribs on the inside need to be machined out.
Re: front rotors
Thanks captainfab. I was affraid of that. Since my truck used to be a delivery truck, it has the heavier brakes on it. Machine shop here I come.
![]() Join Date: Mar 2008
Re: front rotors
I did it years ago and so I could get a 3.5 wheel and it worked fine. I ended up later going to Strange brakes
NHRA Super Street 469C It only runs 10.90 at 156 mph |
It's Better With Nitro
Re: front rotors
Yes, I drilled mine many years ago to fit a set of vintage 4.5 wide wheels up front.
Thread Tools | |
Display Modes | |
