5on5 to 5on4 3/4 swap question
i called weld racing wheel and the wheel im going with only comes in 5on4 3/4 so my question is is there a rotor out there that i can swap over to from a car camaro, impala, nova, monte carlo? i know most of the big body cars share the same spindles and some are 5on5.
i just dont want to have to redill my rotors and have the snout turned down everytime i have to replace a rotor. |
Re: 5on5 to 5on4 3/4 swap question
I do know that the S10/Sonoma and Blazers/Jimmys also use that same bolt pattern. You could go to a junk yard and get one cheap and try it. I did this before but my Uncle is a Machinist and he took it to work and drilled them out? Good luck
Search is your friend
Posted via Mobile Device |
![]() Join Date: Sep 2009
S-10 is 5 on 4.75
Experience is something you gain when you didn't get what you wanted in the first place. No great defeat was ever just possible in the beginning. |
67-72 parts collector,…
![]() Join Date: Nov 2002
I've heard the 73-87 light duty c10 spindles (for 1" truck rotors),... will accept a '91 Camaro 1le rotor that is the 5x4.75 pattern.
I have never done this myself. Read this: http://67-72chevytrucks.com/vboard/s...d.php?t=319487
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-23-2013 at 08:36 AM. |
ive done a search on here and google and came up with nothing..
The link I posted tells you how.
Did you read it? Rotor comparison: 81-87 Truck rotor specs are: Height 4.63 Diameter 11.86 Min. Thickness .96 Hub 3.20 Outer bearing A-3 Inner bearing A-6 Seal Part # 8871 Bolt Circle 5X5 91 Camaro 1LE Performance Package rotor specs are: Height 4.65 Diameter 11.85 Min. Thickness .97 Hub 2.78 Outer bearing A-3 Inner bearing A-6 Seal Part # 8871 Bolt Circle 5X4.75
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-22-2013 at 07:31 AM. |
sorry i over looked the link you posted thank you for the link
so those rotors will fit with out any problems? |
Do you have the light duty spindles?
havent checked for sure yet but from what im reading my truck being a 85 they should be the thin ones. will look tomorrow to be sure, but if there the thin will the D52 calipers work?
Your truck could be either.
Wilwood D52s can be purchased for either width rotors. Posted via Mobile Device
does anyone know how to change the 8.5 to a 4.75 bolt spacing ...
axle length should be the first place to look .. i do not have access to these books |
#13 |
![]() Join Date: Jun 2009
Just take the axles to a machine shop and have them drill them. It really isn't a big deal for a shop with the right equipment. I have a friend that is a machinist and he just drilled his axles for whatever bolt pattern wheels he wanted.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#14 |
Im going to have a set of stronger axles made with the car wheel pattern. While Im there Im doing away with the C-clips and having new ends put on my housing..
But i did check my rotors are the 1 inch thick ones.. So all i have to get it a set of 91 camero rotors and that's it. Do i need the camero bearings or will the truck ones work? Posted via Mobile Device |
#15 |
The truck bearings will work,... but I would get new ones.
Just remember to get '91-92 Camaro 1LE optioned rotors. (the 1991 Camaros were offered with the 1LE rotors mid year) These rotors are different than the standard 82-92 camaro rotors.
#16 |
Ok cool deal.. Thank you sir
Thread Tools | |
Display Modes | |
