03-22-2013, 10:17 AM | #1 |
C/10 junkie
Going on air, some advice please
Ok I am slowly building up my air ride parts swap. I have a set of Slam Specialties SS-7 bags and rear plates on the way, thanks Keith. For now I will probably run shraders. I want to start with getting the tank and compressor. I already have the front bag plates, Thanks Gilbert. So I will go with another set of SS-7s for the front. Will this tank and compressor do the trick? I am thinking of going with DLOE's manual valves. Thoughts? Am I on the right track?
http://www.ebay.com/itm/181090615635...84.m1423.l2649 http://www.ebay.com/itm/370758087072...84.m1423.l2649
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-22-2013, 10:37 AM | #2 |
Happy to be here
Re: Going on air, some advice please
Those are good choices, I would just add to them. The cost of a ViAir twin pack is so cheap that I would but two and run a back up. The 3 gallon tank is enough for one end, but not both. I would run two 3 gallon, or one 5 gallon.
03-22-2013, 10:50 AM | #3 | |
C/10 junkie
03-22-2013, 10:57 AM | #4 |
Happy to be here
One 5 gallon or two 3 gallon will give you enough air for a full suspension cycle with out a refill. The Viair compressors are really reliable so one will work, but two is alwys better for faster fill times and back in the event one ever did fail.
I'll post some diagrams in a few..
03-22-2013, 11:07 AM | #5 |
Square
hey, I plan on running one viair 400 with a 3 gallon tank also with my 59 im building. I chose this set up based on the fact that Dino has used it on the last three trucks he built, along with dloe valves and it has worked really well..
Squarebody Syndicate |
03-22-2013, 12:17 PM | #6 |
I agree with Ken... an ideal setup is 2 compressors with a 5 gallon tank. Although we do a 4 gallon tank with our air management kits, but use 200 PSI. You can always add a second compressors later, but as mentioned, it is a little cheaper in the long run to get a dual pack from the start. Plus the dual 400 pack comes with a pressure switch and 2 relays.
I can get you a single chrome 400C for cheaper than that eBay listed if interested. Of course, I can get the tanks as well. The aluminum run a little more, but you don't have to worry about them rusting and they are very light. The 3 gallon will lift the front, but might take a little bit to gain pressure again for the rear. The rear doesn't take much because it is light. - Travis |
03-22-2013, 01:33 PM | #7 | ||
C/10 junkie
03-22-2013, 01:40 PM | #8 |
Tot Roddin'
Keep in with Travis and he will get you squared away.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-22-2013, 03:12 PM | #9 | |
Thanks! |
03-23-2013, 12:52 PM | #10 |
Young gun
I am also interested in seeing the air line diagrams
67 SWB Custom "JANE" http://67-72chevytrucks.com/vboard/s...d.php?t=554024 Northwest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ Cameron sparks |
03-23-2013, 03:05 PM | #11 |
Happy to be here
What do you call working "really well"? I have two three gallon tanks, and I get one full up cycle from aired out. If I needed to cycle again the tanks have to fill first.
03-24-2013, 10:00 AM | #12 | |
Square
well to be honest here in az we have smooth flat roads where ever we go. so we lift our trucks maybe a couple inches and take off. one 3 gallon tank will get the front and read high enough to get going. if needed to lift the whole truck up the whole way you might have to wait another 30-45 seconds for the comp to fill again. (this is what I have seen with Dinos trucks) my last truck had an engine driven compressor and a 5 gallon tank and I noticed that I had all this air, and a really fast compressor that I went out of my way to get, and never used it. I wasn't much for playing with the switches while I drove so basically seemed overkill. also, with the Dloe valves you probably gain another 1/2 gallon or so since the lines running to the switches act like air storage too..
03-24-2013, 11:38 AM | #13 |
Happy to be here
I suppose it depends on your needs then. I always leave my truck at ride height when parked so I can tell if it ever leaks. To exit my driveway I need full lift, then back to ride height. When I park, of course I air out then back to cruise height. I'm not one for clowning, but I do cycle the system enough to know that 3 gallons would be on the low side of capacity.
03-24-2013, 11:44 AM | #14 |
C/10 junkie
Great advice guys. I was talking to Travis about a 4 gallon tank. Haha
03-25-2013, 11:02 AM | #15 |
You are on the right track, and talking to the right people. I have the twin chrome 480's from Travis, and a 9 gallon tank from ebay (chrome and just $70, shipped). I run 200 psi, so my compressors dont run a whole lot. I don't play much either. I can try to get you some pics of my hose routing, and I am curious to see the diagram, too. Where are you mounting your tank/compressors?
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
03-25-2013, 11:21 AM | #16 | |
C/10 junkie
03-25-2013, 12:08 PM | #17 |
The plumbing will vary depending on your tank ports, but here is the plumbing diagram for the manual and our Pro2 air management kits.
Manual System Pro2 System - Travis |
03-25-2013, 12:12 PM | #18 |
C/10 junkie
Thanks Travis!! I was looking on your web site and I think I'll go with the 5 gallon tank when ready, looks like its only a $5 difference?
03-25-2013, 04:23 PM | #19 |
No problem.... yep, 5 gallon is only $5 more.
03-25-2013, 11:23 PM | #20 |
C/10 junkie
Hey guys will this kit work for temporary shrader set up with the SS7 bags?
http://bit.ly/15NI2AO Posted via Mobile Device
03-25-2013, 11:53 PM | #21 | |
On my current truck I am using manual valves like the one that Travis is selling. They were only right around $100.00 for all for plus a little bit more for the tubing you can adjust the suspension on the road. I don't know how fast you want to get this on the road but it's worth the wait and is a lot eaiser then doing the trial and error for the best ride. On another note, I am using a 5 gal. tank and 2 Viair compressors on my truck. I made a mount for the compressors for under the bed and the tank is in the cab behind the seat. I purchased the compressors through Travis and it was a great price. His company is great to deal with. Good luck on the project and have a good night.
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
03-26-2013, 01:01 AM | #22 |
Too dark for pics when I got home, will try again tomorrow. I think the closer to the center of your truck you mount the tank, the more simple it is, and less hose. also make sure you use the push type fittings that Travis sells. If you, say, forgot to order the fittings that go in your bags and try to put something together from Lowe's IT WILL LEAK! (or so I've heard, lol) I ran my lines from my rear bags up into the channel in the crossmember that the upper shock mounts are on, then up inside the frame rail. I ran the lines from the front bags inside the engine cross member everything comes together on the driver side, and runs through the firewall where thi windshield washer pump lines used to run. I'lll work on some pics. No more than the manual valves cost, I wouldn't mess with the schraders. The whole point is being able to drop it in all the parking lots, right?
03-26-2013, 07:25 AM | #23 |
C/10 junkie
Thanks Matt. I definitely want to be able to drop it when I park it and then up and go I was just thinking its gonna be a couple months while I build the rest of the systems so in the meantime I would run the shrader valves so I could at least mount the rear bags. I guess I'm just impatient and want to put on what I have when I get it
03-28-2013, 12:47 AM | #24 |
I'm the same way, man! It costs me a lot of money, too! lol
03-28-2013, 06:48 AM | #25 |
If you are keeping your truck, then install the bags on shraders for now and then save up for the Accuair air management kit. Its the best out there and the eLevel cant be beat. Dont waste your time with individual valves. By the time you get all the valves and DOT fittings, you will be at the same price as a manifold. Easy push to connect and no leaks. Even if you dont want to spend too much money, get a 3 gal tank, one compressor and the accuair VU-4 manifold and wire it up to whatever switchbox you like.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
Thread Tools | |
Display Modes | |
