03-22-2013, 02:50 PM | #1 |
Question / Help
I have 67 C10 LWB 250 CI.
The other day i was looking at my engine and ujust happened to grab my fan and give it a lil wiggle back and forth in direction of rotation. To my suprise it moved about half an inch in each direction. My guess is that the crank key has sheered and is alowing it to rotate. Any suggestions. |
03-22-2013, 03:16 PM | #2 |
Re: Question / Help
Think your fan hooks to your water pump and not the crank? It will also spin as the fan belt will slip.
edited by staff Last edited by Davemotohead; 03-22-2013 at 03:44 PM. |
03-22-2013, 03:39 PM | #3 |
Re: Question / Help
maybe buy yourself a service manual with pictures
03-22-2013, 04:23 PM | #4 |
Re: Question / Help
i do understand that the fan will spin but. the crank pully moves when i move the fan and yes i know the fan is connected to the water pump.
03-22-2013, 04:29 PM | #5 |
Re: Question / Help
sometimes you can turn the entire crank easy if the fan grabs the belt,I often turn my crank by grabing the fan belt and giving it a pull, pull off the pully if you think the keyway is bad and check?
edited by staff |
03-22-2013, 04:33 PM | #6 |
Re: Question / Help
My guess is keyway i can move it with one finger.
03-22-2013, 04:36 PM | #7 |
Re: Question / Help
Take the Pully bolt out and then look at the crank when you spin the pully and see if its spinning on the crank?
edited by staff |
03-22-2013, 04:50 PM | #8 |
Re: Question / Help
If is is spinning on the crank your alt light would be on and more than likely it would be over heating
69 Chevy 4x4 383 Power |
03-22-2013, 04:59 PM | #9 |
Re: Question / Help
there is no pulley bolt unless someone has drilled and tapped it... sounds like something is not quite right...
03-22-2013, 05:10 PM | #10 |
Re: Question / Help
I have seen what you are talking about before When you remove balancer keyway in crank will probally be bad Balancer will probally come off with your hands If crank is tapped for a bolt epoxie a new key in crank and replace balancer If not tapped see if you can tap it for a bolt Otherwise you will have to replace crankshaft The only other alternative (and not a proper fix)is to spot weld balancer to crank to get you by until you can pull engine and fix it right
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
03-22-2013, 05:13 PM | #11 |
Re: Question / Help
my volt meter is still registering volts and it has not died yet.
Faribran there is a bolt in the crank pully not sure when it was put in. i picked up the truck last july. |
03-22-2013, 05:25 PM | #12 |
Re: Question / Help
That is probably why someone put the bolt in because the snout on the crank is worn. You could be lucky and the inside of the dampner is what is worn
04-15-2013, 03:03 PM | #13 | |
Re: Question / Help
so sunday i decided to change water pump and hoses. and find out why my balancer rotates a half an inch each direction. this is what i found.. |
04-15-2013, 03:12 PM | #14 |
Proprietor of Dale's Corner
Re: Question / Help
Yep.... that would do it, it should have been leaking alot of oil as well the seal has grooved the snot out of it.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
04-15-2013, 04:03 PM | #15 |
Re: Question / Help
oh yes she was covered in caked on oil i was putting about a quart a week in.
04-15-2013, 04:08 PM | #16 |
Re: Question / Help
so can this crank be save any thoughts
04-15-2013, 05:20 PM | #17 |
Cluster King
Re: Question / Help
The crank needs to be repaired which means the crank has to come out of the engine and be welded and repaired by a machinist.
If you put a new balancer on that crank without repairing it, the same thing will happen again. From the photo you posted, it already looks like someone tried to do a "get by for now" repair. |
04-15-2013, 05:51 PM | #18 |
Re: Question / Help
That keyway looks to be wollered out. It also looks like someone tryed to peen it with a centerpunch to tighten things up. I hate to say it.. pull it out and get a crank or have that one repaired
04-15-2013, 08:42 PM | #19 |
Re: Question / Help
yeah thats what i might have to do but not sure if a machine shop can fix that.???
also thinking of getting a rebuild one to drop in place but being active duty navy kind of hard on the pocket... |
Thread Tools | |
Display Modes | |
