65 4x4 on a 80s frame
A good friend picked up a 65 4x4 with a PERFECT CAB and nose The bed is in decent shape and today we got a set of rear fenders But after looking at the frame it has been patched and not worth saving We are thinking about putting the body on a 1986 frame and using the complete drive train Thinking that it should be a easy swap but figured I would ask to see what you guys have done
1961 crewcab
Re: 65 4x4 on a 80s frame
stuff you will need to do:
it will need about a 2/4 inch body lift for the cab to clear the center crossmember the wheelbase is a bit longer 131.5-vs 127 for the 60-66 the 60-66 front bumper mounts to the frame, so be sure to save the first foot or so of frame.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thanks for the input
![]() Join Date: Mar 2011
Use a suburban frame, check out ky-donzi's build http://67-72chevytrucks.com/vboard/s...d.php?t=537789
63 k20 with cummins 4bt, owned sence 1982 |
Sent you a message, may have an easier alternative for you....
I will tell my buddy that owns it about the frame Thanks I am just the helper on this one Mine is a 79 lowboy
Cool, I hope it helps......just not my thing, I'm a down low roller......
Hey moonshiner I know of a yard with several 60-66 trucks in Thompson Ct. Baught some parts a couple of months ago,.cheap. There cleaning out the yard, Got a lot of small stuff. Is it a lwb or shorty?
Its a shorty I am in Griswold Send me some info THANKS
Thread Tools | |
Display Modes | |
