Old 03-23-2013, 05:51 PM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
When did the return lines start appearing??
I'm having a problem with my new '72 1ton GMC. It's a 350/4bbl and so far as I can tell it has only a supply, no return. The build date is 11/71 if that makes a difference.
Anyway, the problem is that I get a fuel starving problem under any kind of load ... new fuel pump and hard/rubber lines on the frame, the line in the cab is original. I'm leaning towards the filter inside the tank?? Could carb filter cause this issue? The fuel siphons from the tank easily and the pump is pushing plenty of fuel sitting still.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 03-23-2013, 08:06 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: When did the return lines start appearing??
I don't think the lines that went to the carbon filter were called return lines, but many people call them that.
In California I think the vapor vent line that went from the gas tank to the carbon filter started in 1971 with C-10s. My '72 GMC 3/4 ton did not have one.
The actual return lines from the fuel pump started sometime after 1972, the '74 454 we put in my '67 had the return line on the fuel pump.
Hopefully someone else will chime in with more info.
Some of the things that can cause fuel starving are plugged fuel filter in Q-jets inlets, collapsing rubber hoses, bad fuel pump, cracked rubber hoses, collapsed sock on sending unit in tank and unvented gas caps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-23-2013, 09:17 PM   #3
JJorgensen52
There is most definitely no charcoal can on this truck, never was, so I think that's out.
I'm going to check the gas cap here in a minute, I'll just swap it with the one from my '69. Also going to check the filter in the Q-jet, didn't think of that yesterday.
CURRENT
SOLD
Old 03-23-2013, 11:13 PM   #4
TripleNickel
TripleNickel's Avatar
My Fremont built, Central Valley delivered '70 C-10 (with October '69 build date) has a return to the tank... and it was a nearly un-optioned 250 with 3 on the tree.
TripleNickel is offline   Reply With Quote
Old 03-24-2013, 12:54 AM   #5
Gumby
Gumby's Avatar
first came about from the heat under the hood of big GMs with AC would cook the fuel causing vapor lock, and was an either or type thing.
Gumby is offline   Reply With Quote
Old 03-24-2013, 01:05 AM   #6
Davemotohead
Davemotohead's Avatar
My CA 71 only had a charcoal canister with no return line,,check the carb stone filter and all the inlet lines,,sometimes you can have a leak that does not leak gas but sucks air when its running.
edited by staff
Davemotohead is offline   Reply With Quote
Thread Tools
Display Modes
