Old 03-28-2013, 03:23 PM   #1
Sloan66
Charcoal Canister Rebuild
I searched the thread and heard others refer to replacing the charcoal in the canister. How does the canister come apart? Thx for the help
Sloan66 is offline   Reply With Quote
Old 03-28-2013, 04:25 PM   #2
Lee H
Lee H's Avatar
Re: Charcoal Canister Rebuild
About the only rebuilding that can be done is changing the charcoal filter. Just snap the top off and replace the bag, about $2 bucks at most DIY auto parts stores.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-28-2013, 05:00 PM   #3
Sloan66
Thanks, I was not sure how it was assembled. I will take a look at mine and see if I can get it apart.
Old 03-28-2013, 08:12 PM   #4
med.bronze
med.bronze's Avatar
If you're successful with this would you mind posting how you did it? I'm curious about this as well. Thanks- Ryan
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
Old 03-28-2013, 09:37 PM   #5
Sloan66
Well, not very successful. My canister is sealed shut, The small cap on top comes off but I do not see where you would fill the canister. The bottom has a what looks like insulation and behind it you can see the charcoal. So I am lost, need input from those who have done this.
I still have the original canister if that matters.
Old 03-28-2013, 10:16 PM   #6
med.bronze
med.bronze's Avatar
I know that the insulation part is a filter which is still available as a AC Delco part but I haven't been able to determine how to "break" into one without ruining the canister. The top part that comes off is the purge valve which is servicable and every now and then I've found nos ones on eBay
1971 K-10 Custom
Old 03-28-2013, 10:38 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
NOS on Ebay now:
http://www.ebay.com/itm/NOS-DELCO-FU...r#ht_145wt_674
and
http://www.ebay.com/itm/1970-75-CHEV...#ht_1154wt_912
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-29-2013, 10:14 AM   #8
Willy Prost
I have cut the canister with a Dremel and a cut off wheel.
Then replace the charcoal with charcoal from the pet store (for aquaraiums).
Then reattach the canister pieces together.
I don't remember, I either used a hot glue gun or PC-7 epoxy to reattach the pieces.
Willy Prost is offline   Reply With Quote
Old 03-29-2013, 12:11 PM   #9
med.bronze
med.bronze's Avatar
Cool! I'm going to try that method....
1971 K-10 Custom
Old 12-31-2013, 08:54 PM   #10
ARC190
ARC190's Avatar
How did the repair work? I think my purge valve is bad. It seems to pass air in either direction but I'd rather not break it by taking it apart.
ARC190 is offline   Reply With Quote
Thread Tools
Display Modes
