Old 04-01-2013, 10:02 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
relays for running high intensity h4's?
Hi guys,
I upgraded to h4's a couple years ago, but the bulbs in there are pretty crappy. I was thinking about upgrading to some better bulbs but have a friend who did the same thing and ended up frying 3 headlight switches before going back to crappy bulbs.
I was thinking of just using a couple 12v/30A bosch 5 prongers. does anyone see a problem with this? should I run a single relay for both sides, or a seperate relay for each light. I can't really see 2 headlights pushing 30A.
I'm running round headlights (pre-80 style)
as well, who makes a bright h4?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-01-2013, 10:43 PM   #2
JellyBeanDriver
Re: relays for running high intensity h4's?
People do this all the time.
Single relay for both sides, one for high beams, one for low.
The factory wires are thin and through all the connectors the voltage drop to the lamps are high.
Come directly off the battery either through a breaker or a fusible link feeding the relays.
JellyBeanDriver is offline   Reply With Quote
Old 04-01-2013, 11:15 PM   #3
mongoose
mongoose's Avatar
yeah have like he said.. one for hi one for low,
then just turn them on with the stock wires.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-02-2013, 01:35 AM   #4
willett
willett's Avatar
How much draw can I expect to be fusing for?
Ed.
P/IE. right... Wattage should be on bulb box...
Old 04-02-2013, 01:44 AM   #5
mongoose
mongoose's Avatar
W/v = a
Old 04-02-2013, 03:27 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can look into the sylvania silverstars alot of people like them with relays. Should take alot of hassle out of wiring for 5 prongs
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-02-2013, 06:31 PM   #7
83GMCK2500
I am in no way affiliated with this vendor, but I do think they have a very well assembled kit: 1973-1987 Chevy & GMC Heavy Duty Headlight Relay Harness
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-03-2013, 12:02 AM   #8
JellyBeanDriver
Ed.
Depends on the H4 bulbs you are using.
Use a breaker if possible. Thermal breakers are slow to respond - helpful for devices with high inrush current like lamps and motors to prevent nuisance trips.
Old 04-03-2013, 03:29 AM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Take a look at the wiring harness that Painless sell for the higher wattage bulbs. The harness comes with two relays and 12 gauge wiring to handle the load. YOu can build a similar wiring harness with items from a parts store, but it takes time and you will have to purchase a pair of male plugs to allow you to tap the headlight circuit for you new relays to actuate.
I would at lest try to copy this for longevity
http://www.painlessperformance.com/w...rchField=30817
http://innovativewiring.com/?page_id=1291
Frank
piecesparts is offline   Reply With Quote
Old 04-03-2013, 07:49 PM   #10
Skunksmash
Skunksmash's Avatar
IMHO there is no need to buy all that. That's way too expensive. I just got two relays and used 18 ga. wire. Made for a nice H4 conversion. Did it about a year ago, still working great today. Bought these headlights:
http://www.ebay.com/itm/4x6-H4651-H4...d02531&vxp=mtr
Bought these nice relays with the fuse already in 'em. So you don't have all that ugly bulk of running in in-line fuse:
HELLA 003530041 12V/25 Amp SPST Mini ISO Relay... HELLA 003530041 12V/25 Amp SPST Mini ISO Relay...
Skunksmash is offline   Reply With Quote
Old 04-04-2013, 02:11 AM   #11
85sierraclassic
85sierraclassic's Avatar
Something like this work? http://www.carid.com/universal-light...FaZFMgodRQ0Amw
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Thread Tools
Display Modes
