Old 04-02-2013, 02:46 PM   #1
DSST_construction
Transfer Case id
ok so on the transfer case, i read this
2c-99404
C-97828
5082
any help would be nice. just trying to make sure that case is the one im thinking it is so when i order parts theres no problems.
also does anyone have any vieos, step by step, or othere info on details to replcaing the seals and o ring in the transfer case its leaking.
DSST_construction is offline   Reply With Quote
Old 04-02-2013, 04:35 PM   #2
RED 1970
Re: Transfer Case id
http://67-72chevytrucks.com/vboard/s...ad.php?t=41428
RED 1970 is offline   Reply With Quote
Old 04-02-2013, 04:57 PM   #3
DSST_construction
thanks, is there any links for fixing the leaks step by step?
Old 04-02-2013, 05:20 PM   #4
RED 1970
If you have a NP205 here's a run down on the rebuild... Might be throwing dynamite at a fly but... http://www.fourwheeler.com/projectbu...d/viewall.html
And this:
http://www.wideopen4x4.com/NP205RebuildGuide.html
Old 04-02-2013, 05:50 PM   #5
DSST_construction
i like the write up on wideopen4x4
if i ever rebuild im using that for sure.
Im really just looking for what seals an o ring i need to buy, how to remove and install the right. Ive looked alot an javent found a dummy version on the site.
Old 04-02-2013, 06:32 PM   #6
RED 1970
Is it a NP205? TH350 or manual transmission?
Old 04-02-2013, 07:00 PM   #7
DSST_construction
auto, i pretty sure its a 205
Old 04-02-2013, 07:01 PM   #8
RED 1970
What seals do you want to replace? Input/output?
Are you going to replace the yokes while you're at it?
Old 04-02-2013, 07:11 PM   #9
DSST_construction
not sure, i was reading on a few other posts and they said to replace 2 seals and a o ring, that should stop the leak
Old 05-02-2013, 02:18 PM   #10
DSST_construction
anyone have a step by step or video on how to replace the seals? im looking to do this soon and want to have the seals orded and a genral idea of what i need to take off or leave one the case
Old 05-02-2013, 03:33 PM   #11
RED 1970
Those cover the entire rebuild process... you should be able to cherry pick the information you need.
Old 05-02-2013, 04:33 PM   #12
DSST_construction
thanks buddy
Thread Tools
Display Modes
