04-06-2013, 10:00 PM | #1 |
1967 C10 SWB
I need starter help!
I have a 1970 C10 with a basically stock 350. I only drive about 1000 miles a year on the weekends.
Here is the problem... Every six months I have to buy a new starter. It works great for about 4 months and then all of the sudden it won't crank the motor once it is hot. After three new Auto Zone starters I bought a Summit high torq starter, wrapped it in a starter insulation kit and it worked for about a year and now it is doing the same thing. I do NOT have headers and the battery and cables are good. Every time I put a new starter on it cranks right up every time for about six months. Please help!!! Posted via Mobile Device Posted via Mobile Device
http://67-72chevytrucks.com/vboard/s....php?p=3867053 |
04-06-2013, 10:10 PM | #2 |
Re: I need starter help!
Here's a good thread on the starter issues of these old trucks !! I have changed all of the old trucks I've owned to a furd style solenoid,,, no more hot start issues and the starters last a lot longer. I had a big block 69 C10 that ate a starter about once a month. After this conversion I never replaced another starter.
http://67-72chevytrucks.com/vboard/s...d.php?t=475748 Hope this helps !! Tom |
04-06-2013, 10:17 PM | #3 |
Msgt USAF Ret
You might try the remote starter kits or make your own. They are designed to fix this exact problem. The idea is to get the most voltage to the starter solenoid possible.
This is one using the ford solenoid. This one uses the Bosch solenoid. This one is the one I prefer.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-06-2013, 10:36 PM | #4 |
That's how I do mine !! |
04-07-2013, 12:55 PM | #5 |
1967 C10 SWB
So once I wire up the Ford solenoid do I need to replace my starter again? I would like to keep high torq on I just bought a year ago if possible.
04-07-2013, 12:58 PM | #6 |
Watch out for your cornhole !
You shouldn't need to resort to modifying for a Ford solenoid. When working properly, there is no reason in the world for your truck to need modifying.
I'd start with doing a voltage drop test on the battery cables and ground straps. No matter how they look or how new, until proven good via testing, they are suspect. Posted via Mobile Device |
04-07-2013, 12:58 PM | #7 |
remove two battery cables
clean all 4ends and where they mount a slight coating of dielectric grease and reinstall battery cables
04-07-2013, 01:55 PM | #8 | |
04-07-2013, 01:57 PM | #9 | |
1967 C10 SWB
I will clean up all connections and see if this helps. What doesn't make sense to me is how putting a new starter on it solves the problem for six months. Does the solenoid ware out after in gets too hot so many times? If the issue is the solenoid getting too hot why don't I have the same problem with a new starter and why does it take six months to a year before I have problems? Posted via Mobile Device Posted via Mobile Device
04-07-2013, 02:09 PM | #10 |
If you have manifolds and reasonably routed exhaust pipes, the starter getting too hot shouldn't be much of an issue.
Don't rule out the cables. I've seen beautiful cables that when slit open, were corroded horribly inside. Posted via Mobile Device |
04-07-2013, 02:12 PM | #11 |
Msgt USAF Ret
Regardless of the debate on whether the modification is really necessary. It does have a beneficial effect of alleviating the high current draw through the ignition key switch circuit. Just like the headlight relay mod and the alternator conversion, as the old saying goes.
NOTHING SUCCEEDS LIKE SUCCESS.
04-07-2013, 02:57 PM | #12 | |
1967 C10 SWB
04-07-2013, 03:21 PM | #13 |
Oil dripping on starter can cause failure.
I would install new high current cables and clean the terminals. If you don't want to buy new cables you can check resistances, amperage and voltage drops to verify in spec. Like TX Firefighter said, a good looking wire can be defective; especially where wire is crimped on terminal. Another option is repair defective wire. I have soldered clean terminals on large wires w/ torch. I wouldn't be surprised if your starters are of such low quality they can't cope. Excess timing advance can over stress starter. |
04-07-2013, 08:49 PM | #14 | |
1967 C10 SWB
I'm going to do a voltage drop test and see what is going on. I'll let you know. Thanks for the help guys. Posted via Mobile Device
04-07-2013, 09:01 PM | #15 |
You'd be surprised. Think of a loose battery cable at your battery. You wiggle it and the car will start. Then over time the car won't start again. Wiggle the cable and it starts again. What you're doing it breaking down the corrosion and allowing it to make better contact. Then the corrosion builds up over time again.
You can take an internally corroded battery cable and bend it which will break down some internal corrosion, but it always corrodes again shortly. Posted via Mobile Device |
04-07-2013, 09:52 PM | #16 | |
1967 C10 SWB
Thanks for all the help! Posted via Mobile Device Posted via Mobile Device
04-07-2013, 11:09 PM | #17 |
This "ford" mod makes no sense to me. You are still using the gm solenoid to engage the starter. So now you have 2 solenoids in your circuit. Maybe I'm missing something.
04-09-2013, 08:56 PM | #18 |
1967 C10 SWB
Can someone explain this to us? I have the same question.
Does it somehow hotwire the Chevy solenoid on the starter? I read the entire other thread on starters and still don't get this. I also didn't get and answer about heat weakining a solenoid above. I really want to learn exactly how his works because I have had this problem for 10 years. Posted via Mobile Device
04-09-2013, 09:34 PM | #19 |
I don't get it either, looks like chevy starter still wont start if chevy solenoid fried. It would make sense if chevy solenoid was completely by-passed.
vexvader, I've only heard of header heat frying starters where header, collector or exhaust pipe is too close to starter. |
04-09-2013, 11:40 PM | #20 | ||
Msgt USAF Ret
The reason the solenoid won't engage is because of the higher resistance in it's windings due to the excess heat. On the stock truck wiring the solenoid power goes from the positive terminal to the junction bolt on the right fender, across the radiator and back up through the cab, to the key switch. then back out through the cab via the purple wire to the solenoid. This is about 15 feet of wiring and due to the resistance of the wiring. even in good condition it will create quite a voltage drop. If you check it during cranking it might be as low as 10 volts instead of 12. When you add this to the extra EMF (voltage pressure) needed to overcome the heat resistance it could be enough to keep the solenoid from engaging. What the remote solenoid does is eliminate all but about three feet of starter solenoid wire. This decreases the voltage drop and lowers the resistance on the starter solenoid. It's even better if it's wired with the jumper to the S terminal right at the solenoid. In most cases the three feet is enough to engage the solenoid. If the solenoid clicks loudly then the remote kit will not help. If it clicks lightly then the kit will help the solenoid to kick out the starter gear and engage the contacts for the starter windings to turn the starter. Contrary to popular belief. The main cable doesn't even have to be connected on the solenoid for it to engage. The starter just won't turn. Even if the cable is corroded inside, the solenoid will still engage unless it jumps right at the solenoid, then of course you will still need the battery power from the cable there. Quote:
This illustrates the amount of wiring to get the solenoid to work. This shows how the solenoid works the starter and the flywheel. This is a view of the inside of the solenoid and shows how it makes contact between the battery cable and the starter windings when the relay closes. This one shows the starter cutaway. Remember it takes a lot more amperage to close the Chevy solenoid than it does the Ford because the Ford solenoid is just a relay and does not have to engage the starter gear. This is why the kit works.
04-09-2013, 11:44 PM | #21 |
Msgt USAF Ret
04-09-2013, 11:51 PM | #22 |
Does that mean a large gauge jumper wire should be used on Chevy solenoid?
04-10-2013, 12:59 AM | #23 |
Msgt USAF Ret
If you mean in the kit then no 12 is enough . Remember the voltage drop is because of the long wire not the gauge of it. I had a picture of a metal jumper some where. I'll look for it.
04-10-2013, 01:04 AM | #24 |
Msgt USAF Ret
Here you go. I don't know if the auto parts sells it or not. Shouldn't be hard to make one.
Thread Tools | |
Display Modes | |
