04-10-2013, 05:10 PM | #1 |
tranc help
does anybody no if you can put a 700r auto tranc in a truck with no computer and make it work right
04-10-2013, 05:56 PM | #2 |
Re: tranc help
What is a "tranc"?
04-10-2013, 06:18 PM | #3 |
Re: tranc help
Yes you can, you need a switch to hook up (12volt) to lock up the Converter, but you do not need a Puter. B&M sells a switch with a slide bar that you can adjust the point when the overdrive engages. I hope this helps.
1965 GMC LWB 383/700R4 1947 Fleetmaster Coupe Supercharged 1955 Chevy Bel Air LS3/6l90e 2012 GMC Denali 2500HD |
04-10-2013, 09:59 PM | #4 |
Re: tranc help
does the switch come on automatically or do you have to turn it on and off
04-10-2013, 10:01 PM | #5 |
Re: tranc help
transmission
04-10-2013, 10:37 PM | #6 |
Re: tranc help
I have a switch in my wifes chevelle that you set where you want to shift and leave it alone .
04-10-2013, 11:02 PM | #7 |
Re: tranc help
You can also modify the valve body to lock up with hydraulic pressure or run a simple jumper harness to lock up when it shifts into 4th. From what others who have done this have said, its cheap and it works , but its a little firm on the shift.
I wanted mine to shift and act as smooth as I could. After reading a bunch of builds and asking how they drove, I ended up with a TCI harness with the supplied vacuum switch. It locks the converter after shifting to 4th and unlocks when it senses a change in engine vacuum or rpm. Works great, easy installand couldn't be happier. Posted via Mobile Device |
04-10-2013, 11:08 PM | #8 |
Re: tranc help
You set the switch where you want it to shift into overdrive and leave it alone, unless you want it to shift sooner, you move it to the left, later u move it to the right. You just have to play with it and see where it suits u.
04-10-2013, 11:29 PM | #9 |
Re: tranc help
Newfisher or Bowtied, do you have a link to what you used?
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
04-11-2013, 12:46 AM | #10 |
Re: tranc help
The unit that I used on my 65 was a B&M controller, I have been using it for about 8 years and it works great. Just Google B&M overdrive controllers and you have to specify if your speedo is mechanical or electronic. There are probably more dealers that make them, but I am very satisfied with mine. It was very easy to install, if this helps.
04-11-2013, 07:30 AM | #11 |
Re: tranc help
thanks everbody for all the help
04-11-2013, 09:35 AM | #12 |
Re: tranc help
04-11-2013, 10:05 AM | #13 |
Re: tranc help
Thread Tools | |
Display Modes | |
