Old 04-18-2013, 11:14 PM   #1
papsoldblue72
papsoldblue72's Avatar
72 longbed driveshaft....
What junkyard driveshaft can I use for my longbed truck and a 350 turbo transmission??? I just pulled the three speed manual out to run a auto and the yolk on the old original is splined different... I know I could just switch the yolk out on the old one but I kind of want to go with a one piece design from another truck... Is there anything that will just bolt up ???
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 04-19-2013, 02:30 PM   #2
chiefcfd
chiefcfd's Avatar
Re: 72 longbed driveshaft....
When I did this I didn't have to change anything, Not sure what the difference would be.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 04-19-2013, 03:01 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
Junkyard shaft the correct length $50
Gas to go from yard to yard to see if their shaft hasn't been trashed by the forklift driver $50
New ujoints for the old shaft $40
Your new junkyard shaft needs to be an inch shorter because your engine mounts aren't the same as the person who gave you advice onlines engine mounts. Cut weld ballance. $60
Your useable junkyard shaft $200
Or you could take your measurements from your truck and your old trans yoke to a driveline shop and have a new shaft in a couple of hours for about $200
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-19-2013, 03:05 PM   #4
brad_man_72
the boat guy
You can just swap out tranny yokes, but you should have your shaft reballanced before you use it.
Thread Tools
Display Modes
