Old 04-21-2013, 02:58 PM   #1
clemsonteg
4 core radiator retainers
Well after some investigation I have found that the radiator that was in my truck appears to be from a 70ish Chevelle. Last week I ordered a new 3 core radiator which was marked for a C10, but after further research it too was for a Chevelle. My problem is with the retainers that bolt to the core support. The tank on the drivers side will accept the standard 3 core mount. The tank on the passenger side is nearly 1" wider and the previous owner made cuts in the 3 core mount to make it fit also pictured below. I'm asking someone to measure the rubber mount area for me and possibly snap a picture to see if I can order a 4 core retainer for the passenger side.
Thanks!
Stock retainers, the bottom one has the cuts
Old radiator, you can see the difference in end tank thickness
Measured the thickness of the driver side tank on the new radiator
And the thickness on the passenger side
clemsonteg is offline   Reply With Quote
Old 04-21-2013, 06:14 PM   #2
vidman
vidman's Avatar
Re: 4 core radiator retainers
There is almost an inch difference between the 2-3 core and 4 core mounts
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 04-21-2013, 06:27 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Order the correct ones from Wes at Clkassic Heartbeat. It's where I got my 4 core rad retainers. They were original GM, and came in NOS packaging. I was quite suprised to see that.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-21-2013, 06:41 PM   #4
clemsonteg
Thanks vidman that was exactly what I was looking for. Looks like I need 4 core mounts for the passenger side.
Old 04-21-2013, 07:12 PM   #5
vidman
vidman's Avatar
Your Welcome and good luck..
Old 04-21-2013, 09:02 PM   #6
Russ.W.
Russ.W.'s Avatar
Great pics vidman.
Was after some info regarding the differences between radiator mounts. Your pics with a measuring tape for clarification were exactly what I needed. Nicely done sir.
Old 04-21-2013, 09:02 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Gary
^This one^ Take measurements of the new radiator have them handy so he can help you match up on the first try.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Thread Tools
Display Modes
