Old 04-22-2013, 11:33 AM   #1
stroker87
line lock / roll control install help?
Hi guys i have not had my truck running for the last 3 year hope to have it running in the next few weeks but befor i get the engine in i wanted to install a line lock kit has any one done this can the tell me the best way to do the brake lines? i'm not worried about the wiring
if you have any info would be great
thanks
its a 1987 with power brakes
stroker87 is offline   Reply With Quote
Old 04-25-2013, 07:48 AM   #2
wraprail
wraprail's Avatar
Re: line lock / roll control install help?
Installs in your front hard line between your master and combo/prop valve
Thats it. Wire a switch on a fused 12 volt circut and thats it.
burn up all the tires you want
wraprail is offline   Reply With Quote
Old 04-25-2013, 08:18 AM   #3
bns454
or install it on your rear brake line to lock them off that way you can move forward/dounuts/fishtails and still have full control thru your footpedal it depends wether you want it for burnouts or to stall it up dragracing without using your foot
also you will need a brake line double flareing tool
bns454 is offline   Reply With Quote
Thread Tools
Display Modes
