Old 04-25-2013, 03:42 PM   #1
956LOUIE
57 rear boxing plates
Any advice or anything to look out for when boxing rear frame on my 57 ?
Links templates or is it cheaper to buy a kit i am running a no limit rear 4link with airbags ?
Bout to work on that this weekend wanna make sure i dont have any surprises
Should i notch it or not ?
956LOUIE is offline   Reply With Quote
Old 04-25-2013, 03:51 PM   #2
dubie
dubie's Avatar
Re: 57 rear boxing plates
I boxed mine in and then cut the c notch. It was all done with 3/16" plate and a piece of rolled 3/16" plate for the arch in the notch. It's not difficult at all, just takes time
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-25-2013, 03:53 PM   #3
956LOUIE
What did u cut with i dont want to make a bad decision ?
Old 04-25-2013, 04:00 PM   #4
dubie
dubie's Avatar
I used my 4 1/2" grinder with a zip cut disc. I used it to cut the traced out shape of my frame and to cut the hole for the notch
Old 04-25-2013, 04:26 PM   #5
956LOUIE
Are the plates supposed to fit inside or ouside of the frame rail ?
Old 04-25-2013, 05:17 PM   #6
_Ogre
_Ogre's Avatar
unless you can flip your frame or like welding overhead for hours at a time i'd cut it to fit inside the frame
that way you can sit on a bucket and weld the top and bottom flanges
i had the metal warehouse cut all my plate to fit inside and trimmed what i needed over the rear axle and where it tapers on the front horns
i removed and fabbed up some x-members and kept some in place and notched around them
if you don't c-notch your frame the lowest you can is about 5'' and the lowest you'll be able to ride is about 8''
i have a 3-4'' notch, standard bed height and am static at 5'' but occasionally hit the bump stops
i would suggest a 5'' notch minimum, more if you don't mind raising the bed more
shop air compressor timer
Thread Tools
Display Modes
