Old 04-29-2013, 07:46 PM   #1
WadmalawJoe
WadmalawJoe's Avatar
Temp gauge questions
I have read through several postings on the gauge and problems. I think I have a different question. The PO removed the old sensor and wire and installed a aftermarket gauge attached below the dash. My main question is once I put a new sensor in, where does the wire go to?
Here is the back of the gauge, everything looks ok there, I think;
jeepers, is the picture big enough? lol
Looking my wiring over I discovered something else. I think my dash cluster maybe out of a 67 (my truck is a 69) The first picture you can barely see the 67 in the circled part, but you can see it in the second picture. Maybe, its just part numbers, but it seems odd to me.
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I知 back!!!
WadmalawJoe is offline   Reply With Quote
Old 04-29-2013, 09:02 PM   #2
502ms
502ms's Avatar
Re: Temp gauge questions
My truck is a 72, the cab has that flat plug, the 67 has the curved plug. I know because we were going to swap columns and the 67 column was curved plug wise.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 04-29-2013, 09:31 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This is the wiring on the gauge cluster plug. The left column is 1 through 6 and the right column is 7 through 12. So the temp wire is on no. 6.
1 and 12 are the battery gauge wires.
Name:  cluster connector with gauges.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-29-2013, 10:33 PM   #4
WadmalawJoe
So that's some kind of adapter to connect the curved to the flat plug.
The motor is actually a 72, so they have taken parts and modified them.
Toys/projects
Old 04-29-2013, 10:34 PM   #5
WadmalawJoe
Attachment 1100494
So I need to dig around up behind my dash and find the 12 pin plug and run my sensor wire to it?
Toys/projects
Old 04-29-2013, 11:20 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes the plug should have the numbers on it.
VetteVet
Old 05-13-2013, 08:01 AM   #7
WadmalawJoe
Thanks VetteVet!!!
I found it, it was simple, just a plug into the back of the cluster.
I also disassembled my dash/cluster, cleaned it, painted tins gloss white and switched to 168 bulbs, trimmed the end of the optic cable to the shift indicator and it works!! I am very pleased
I need to take a night picture with it all lit up, the day picture doesn't do it justice so I'm not posting it.
I had picked up the temp sensor from Napa $8.95. It is 3/4 size thread and the sensor ports on both heads is a 1/2". I either have different heads or Napa had the sensor wrong? I put it in the intake port, right next to the thermostat location. My gauge reads around the 1/2 and 3/4 way area, once its good and warmed up. Also, the PO had put a 160 degree thermostat in!! No wonder the engine never got all that hot, I switched it out for the 190. He even had put a 4 core radiator in (no A/C). I'm not sure why the low thermostat?
Anyone know what size their sensor port/hole is? My truck has a 72 350 in it.
Also, any ideas on the low thermostat? He must have had a temperature problem with it or was scared of it getting hot or maybe thought, the cooler the better??
Toys/projects
Old 05-14-2013, 06:14 AM   #8
MikeyMan
What was the part number of your NAPA temp sensor?
The holes in the cylinder heads are 1/2"
I have a mechanical (bulb type) sensor for an aftermarket temp gauge in my DS head.
My PS head has a plug in it that I cannot get to bust loose.
I have a 3/8" port in the intake that I would like to put a sensor in to operate the factory stock temp gauge.
MikeyMan is offline   Reply With Quote
Old 05-14-2013, 07:56 AM   #9
WadmalawJoe
The Napa part number was MPE TS6469SB. It is 3/4 inch thread though. I have an edelbrock intake, which happened to have that size hole right next to the thermostat.
Toys/projects
Thread Tools
Display Modes
