fuel pump replacement, fitment question
I need to replace my fuel pump on my 70 c20 small block. It has a newer. motor with center bolt heads and the numbers on the pad decode to 87 or later. Would I just buy one for a 70 c20 and it will fit? Are all SBC with machanical pumps the same pump? I went to my local parts store and they were clueless to my question.
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying" |
Re: fuel pump replacement, fitment question
Yes, get one for your original truck.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Yep, I agree
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Check your block carefully. Some of the new SBC have a mounting boss for a mechanical pump, but are not drilled for the push rod.
![]() Join Date: May 2012
they make a two line and three line pump...should be able to find the one you need , just look at the one you have now..
Thread Tools | |
Display Modes | |
