Old 06-23-2003, 06:49 PM   #1
76bonanza
76bonanza's Avatar
np203 question
I have a np203 that has been converted to part time with locking hubs and transfer case work. Here is my question when in 2 wheel drive daily driving should the transfer case be in nutruel or in 2 wheel high? I some times can not tell if it is in 2 wheel high or starting to go into high lock? But I can tell when it is in nutreul?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-23-2003, 11:40 PM   #2
mkmiller1
mkmiller1's Avatar
I believe you should run it in 2HI. With the transfer in Neutral you should get NO power to either axle. Also with the part-time kit, you should shift the transfer into 4HI or 4LO about every 200 miles to get fluid to the pump in the rear of the case. The way I would remember is just to lock it in everytime I filled up with gas and then throw it back into 2HI about 10 miles down the road.
Hope this helps,
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Thread Tools
Display Modes
