Old 05-06-2013, 02:24 PM   #1
Coconut-kid
Fulton visor dogbone height
As the title says. Could anyone with a fulton or reproduction Fulton visor please let me know what hieght their visor dogbones are mounted at. I search the web and have come up with about four different heights anywhere from 10 to 12 3/4. So if you're running a visor could you please do a check for me I'd appreciate it.
Coconut-kid is offline   Reply With Quote
Old 05-06-2013, 04:25 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Fulton visor dogbone height
Sorry I can't help, I have a Fulton but its not the dog bone style. Mabey check the air bagged thread and PM one of the guys. There seems to be a few in that thread if I remember.
NEWFISHER is offline   Reply With Quote
Old 05-06-2013, 08:33 PM   #3
parkwood
parkwood's Avatar
I can't tell you what the measurement is because i don't have the car any longer here. but i hope the pictures help. I will tell you that i had to move the dogbones up and down to find a place where they fit the door post and looked good too. You will have to bend and grind to get them to fit but take your time and mock it up and put it where it fits and looks right..
parkwood is offline   Reply With Quote
Old 05-06-2013, 08:46 PM   #4
Root2812
Root2812's Avatar
Parkwood, what did you use to attach the visor in the door frame? I was thinking self tapping screws but I would think they would need to be pretty flush.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 05-06-2013, 09:16 PM   #5
parkwood
parkwood's Avatar
If i remember right i used 10/24 or 10/32 flat head allen screws. and you're right they have to be flat because there isn't much room as the door closes. i had to grind the doors just a bit to get them to clear as it was... not sure if you can see the difference in the door gaps from the two pictures..
Old 05-06-2013, 09:41 PM   #6
Root2812
Root2812's Avatar
Maybe rivets would be a good route to go.
My 1950 Chevy build
Old 05-07-2013, 12:16 AM   #7
parkwood
parkwood's Avatar
I'm not sure the head of a rivet would be strong enough to hold it.. remember that thing catches a lot of air at frwy speed.
Old 05-07-2013, 12:08 PM   #8
Root2812
Root2812's Avatar
Hey coconut kid,
I found this instructions page. Seems pretty good.
http://53truck.ez15loan.com/howto/fulton-spec.htm
My 1950 Chevy build
Old 05-09-2013, 02:30 AM   #9
Coconut-kid
@parkwood. Thanks for all the info and pics.
Thanks for the link root. I found those and some others.
Im going to mount it so the top edge is just over the top of the window seal. Ill mock it up first and adjust from there.
Thanks again everyone.
Old 03-06-2015, 05:25 PM   #10
lower50's
lower50's's Avatar
measured today from bottom of drip rail
hope it helps
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-06-2015, 05:54 PM   #11
joliver33
I mounted mine 10.5" up measuring from the bottom of the drip rail up to the lower edge of the dog-bone mounting flange.
joliver33 is offline   Reply With Quote
Old 03-07-2015, 02:12 AM   #12
Donaldo
Thanks, these are the answers and pics I had hoped for in another post. 10.5" should be fine .
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Thread Tools
Display Modes
