Old 05-10-2013, 04:47 PM   #1
BiggSixx1970
Angry It just never ends! (sorry, kinda long)
I love my Chevy, its a 43 year old daily driver I picked up last year, for the most part it's been a damn good running truck for the year I have owned her. being all original but it seems when it rains, it pours. When it has a problem, they come in pairs!(or more)
Now the novice sunday shade tree mechanic in me is stumped.
It received a tune up last spring: Fuel pump, new distributor, plugs, plug wires, fuel filter, air filter, carb rebuild, coil, battery, oil change to high mileage blend, fuel pump.
It has ran like a top every since then, It received another tune up this spring as well: spark plugs, new heater hoses, new upper and lower radiator hoses, full cooling system flush, new thermostat, new air filter, new fuel filter, this was all TWO WEEKS AGO
So my dad makes the comment to me, "hopefully your water pump doesn't go out, Chevy's like to do that when you flush their radiators from my experiences"
Well, the old man totally jinxed me and it appears I'm getting a little weep action from the water pump now, noticed as of the other day (no biggie, water pump is no big deal to replace)
The problem now is for whatever reason, my engine keeps shutting off unless i give it gas, accelerating or slowing down in gear(its a manual). When I push in the clutch, if i'm not giving it gas, the idle drops really slow, then it dies.. Thoughts?
Thanks for the help! You guys are awesome
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up!
http://67-72chevytrucks.com/vboard/s...d.php?t=545486
Gentlemen wear a bow tie.
BiggSixx1970 is offline   Reply With Quote
Old 05-10-2013, 04:57 PM   #2
tommys72
tommys72's Avatar
Re: It just never ends! (sorry, kinda long)
My cavalier did the same thing, flushed the system and bam...water pump goes bad...the fuel thing sounds to me like the filter is clogged maybe, or carb needs cleaned. Giving it gas makes enough pressure to get past the clog but not at idle
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-10-2013, 05:03 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Start with the EZPZ stuff. Fuel filter...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-10-2013, 05:09 PM   #4
BiggSixx1970
I just put a new one on a couple weeks ago though, its cheap and easy to replace but I did just put a new one on
Old 05-10-2013, 05:21 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a few things that will cause that.
1. Carb idle screw.
2. Carb mixture screw
3 distributor retarded too much.
4. vacuum line off the advance or the carb.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-10-2013, 05:41 PM   #6
BiggSixx1970
1. Carb idle screw.
Ah the vacuum advance! I didn't think about that, It got a new distributor last summer, with a new advance, buut the line into the carb is a little sketchy
The weather here has been verrrry wet, cool, and very humid. I know that can play havoc on carbs. But I don't see why my distributor would go out of time, doesn't that normally take something catastrophic?
Messing with the fuel/air mix on the carb is something I know NOTHING about, I was always told if it's working fine (which it has been until now) not to go muckin' around with your carb. It is a Rochester Mono-jet so there's only two screws on it, but I haven't touched those cause I don't wanna goof anything up. After I gave it a good tune up last spring/summer my buddy's dad who's worked on his share of these things got under the hood with a screwdriver and 'tuned' my carb for me and it has ran great since, I don't know why the screws would back off or sink in further messing with the mixture, but hey i've seen weirder things happen!
Appreciate the replies!
Old 05-10-2013, 08:38 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
those distributors have a hold down bolt to keep them from turning but if they're not tight enough the distributor will turn. I thought you might have bumped the vacuum advance diaphragm while changing the water pump and moved it.
The mixture screws are best adjusted with a vacuum gauge for highest vacuum at idle but it's easy if you have the gauge/ You just turn them in or out until you get the best vacuum and then set the idle screw so the engine idles at the proper RPM. They don't usually move on there own so that may not be the problem.
VetteVet
Old 05-10-2013, 09:06 PM   #8
BruthaMan
US Army Veteran
BruthaMan's Avatar
I can sympathize with you, for sure. Some days I wonder if things like this happen to others, or if it's just me. When it rains, it pours...welcome to Noah's Ark!
As others have suggested, check all of your vacuum lines. Check PVC valve (driver's side valve cover on mine, but is GM crate motor) to carburetor.
One morning this past winter, after another sleepless night, I headed out to get some donuts. Truck was running abnormally rough, even for being cold. Shortly after I departed, I pulled over into a Walmart parking lot. Got the flashlight out and sure enough, a vacuum line had come off.
Was running very rough, barely staying started. After plugging the vacuum line back in, everything smoothed out.
Same happened with the PVC valve once. Had popped out of the valve cover and running rough.
Hope that helps. Don't let it get you down. Just remember, it happens to "bruthaman" too!
BruthaMan is offline   Reply With Quote
Old 05-11-2013, 12:02 AM   #9
domeier
domeier's Avatar
Clogged idle jet will do that. What carb do you have?
domeier is offline   Reply With Quote
Old 05-11-2013, 01:14 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
One more question.Did you change the filter in the carb or does it have an inline?The one in the carb will be behind the 1' fitting the fuel line screws into.It could still be in there even with an inline and may be clogged.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-15-2013, 11:31 PM   #11
BiggSixx1970
There is no longer a filter in the carb, I took it out when I stripped out the fuel inlet to the carb (oops!).. So I sealed it shut last summer with some JBWeld and installed a plastic inline before the fuel pump
Old 05-15-2013, 11:32 PM   #12
BiggSixx1970
Rochester Mono-Jet
Old 05-16-2013, 01:45 AM   #13
domeier
domeier's Avatar
"...When I push in the clutch, if i'm not giving it gas, the idle drops really slow, then it dies..."
That's really weird. Maybe the clutch linkage is interfering with the throttle linkage?
Old 05-16-2013, 08:40 AM   #14
CC69Rat
CC69Rat's Avatar
Vacuum leak somewhere - VA on the dist, or maybe to the brake booster.
My 70 was doing this exact thing last weekend after I swapped the brakes out. As it turns out we just forgot to connect the vacuum line to the brake booster. As soon as it was connected back up, it was fine.
Does it smell like it's running really rich if you just let is sit, idle , and die .. ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-20-2013, 08:57 PM   #15
BiggSixx1970
There are no power brakes, so no booster. I will check my vacuum advance, and make sure its sealed up.. But If the vacuum advance is disconnected, it should still idle correctly, because you have to remove the vacuum advance when you go to set timing. (which I did last summer when i replaced the distributor) You time the engine without the vacuum advance connected if i remember right
Old 05-20-2013, 08:58 PM   #16
BiggSixx1970
No sir, there is a large gap in between the two sets of linkage
Old 06-03-2013, 01:09 AM   #17
BiggSixx1970
Still haven't figured out my fuel gremlin yet.. Replaced my fuel filter again, no positive result. I foresee a carb rebuild? maybe somethings gummed up there, or in a fuel line.
Old 06-03-2013, 03:00 AM   #18
yukon
You might check your distributor cap, since you said it has been humid there. Condensation and corrosion are a common problem on cheap caps.
yukon is offline   Reply With Quote
Thread Tools
Display Modes
