Old 05-10-2013, 08:23 PM   #1
plumber36757
1969 Painted Grille???????
Any one Paint there 1969 Grille???? Lets take a Look At Them. I cant seem to find any one who can Restore it here in Texas go Figure.
plumber36757 is offline   Reply With Quote
Old 05-10-2013, 11:17 PM   #2
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Re: 1969 Painted Grille???????
Chevy or GMC
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 05-10-2013, 11:44 PM   #3
Mister-B
Why not just restore yours yourself properly, rather than painting over it? Here's my thread on how to do it
http://67-72chevytrucks.com/vboard/s...le+restoration
Mister-B is offline   Reply With Quote
Old 05-11-2013, 07:12 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I just recently did the one for my 69 wrecker. I went through years thinking these were black but learned they were actually a gray color.
I matched the gray color of my original as closely as I could to what was on my shelf. Summit stainless steel was the winner. (no longer available btw)
The ends were painted black so I redid those in semi-gloss Krylon.
I think it looks pretty sharp.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-11-2013, 07:21 AM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
^^Nice job Bob!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 05-11-2013, 09:32 AM   #6
Mister-B
Looks really good. My research led me to believe a little differently about the grille insert original colors. I found that the upper and lower flat edges of the insert (as well as the right and left edges like you have it) are supposed to be black, while the squares are more of a metallic gray. What happens, is that those flat edges get a lot of sun, and they fade to a gray over the years. The 70 grille is identical, except for there are vertical channel indentations that were black to create a vertical bars look
Old 05-11-2013, 09:34 AM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That looks factory mang!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-11-2013, 09:43 AM   #8
Mister-B
Oh, and to further complicate things, reproduction GM outer grilles were painted differently than factory grilles that came on the trucks. On the reproduction grilles, there was a black square painted just outside the marker lights on either side, as you have done. On factory original grilles, there was no square, and instead the lines carried over. Also, the upper and lower vertical line paint stayed inside the indentations, rather than filling it and creating an edge above and below.
What you did looks awesome! Just clarifying for anyone trying to get it exactly as it rolled off the assembly line
Old 05-11-2013, 12:14 PM   #9
FirstOwner69
FirstOwner69's Avatar
Not quite correct.
Every original 69 inner grille I've seen (as well as mine when the truck was new) had the "upper and lower flat edges", as you refer to them, painted silver/gray to match the egg crate portions as bobs409 has done. The 70 inner grille was all black plastic (not painted) with 6 raised sections on each horizontal egg crate bar which were silver or chrome.
The outer grille Bob shows is as you describe in post #8, but factory replacements as early as 1972 were, as you correctly noted, different from the originals. I know this as a fact since mine had to be replaced in 1972. This was/is not just the reproductions currently being sold.
FirstOwner69 is offline   Reply With Quote
Old 05-11-2013, 02:02 PM   #10
Mister-B
Originally Posted by FirstOwner69 View Post
Not quite correct.
Well, here's a pic of a supposedly new in box insert, and as you can see, the edges are black as I described
Also, here's a close up of an original '70 grille insert, that shows both the channel grooves, and the black paint. I've verified this on a couple occasions with '70 grilles I've seen at the yard or purchased from the yard. Also note the black edges
Old 05-11-2013, 06:25 PM   #11
FirstOwner69
We are way off the Op's question at this point which I THINK was a request to see pics of completely painted grilles, outer and inner.
But, since we are on this topic...
As I said in my previous post I agree with everything you said about the outer grilles. I was only noting that as early as 1972 GM had changed the tooling and paint application on the outer grille service replacements. I also tried to describe the inner 1970 grille exactly as the picture you supplied.
However, where we differ, is what the original 1969 inner grilles looked like. In 1972, after some clown took out the left front of my truck with his car, all GM could supply for the repair was the incorrect outer grille service replacement and a 1970 inner grille. I suspect that the inner grille in the picture with the box was a later GM compromise between the 2 years. It appears to be just like the current reproductions, which are also incorrect for either year. In fact, I bet if you look closely you'll see the raised areas on the horizontal bars are present which were silver on the 70s. I believe, and can verify with a quick junkyard check on Monday, that the 69 did not have the "steps" in the horizontal egg crate bars. I'll take a camera with me to get some pics. Also, I think if you look more closely at an original 69 inner grille, you'l see that what you thought was weathered black plastic was, in fact, weathered silver paint which is allowing the black plastic to show through.
Old 05-11-2013, 08:55 PM   #12
plumber36757
Painted outer grilles. Sorry guys.
Old 05-11-2013, 09:14 PM   #13
GoaterAz
GoaterAz's Avatar
I don't have any straight on shots saved, but hopefully these help.
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 05-12-2013, 06:36 AM   #14
bobs409
bobs409's Avatar
No problem, I got to show off my new grill anyway.
Just to be "politically correct", the part your asking about is the "grill surround" which is the aluminum part.
Bob
Old 05-12-2013, 10:39 AM   #15
Mister-B
We're getting closer. Yes, the 70 inner grille has the notches, where they then painted them black. The '69 does not have the notches. My inner grille is an original '69, and it does not have the notches in the plastic. I think part of the confusion came when somebody got in an accident and purchased an inner grille for their '69 or '70. Apparently GM's repro supplier decided to take a '70 inner grille with the notches in it, and paint all the squares a metallic gray, thereby ignoring the black vertical line it created for a 70, and adding the notches to a '69 that shouldn't be there.
I'm also not sure about the theory that faded inner grilles turn black. Here's my original '69 grille before and then after.
Here's the after shot
Thread Tools
Display Modes
