05-19-2013, 08:08 PM | #1 |
Gas cap not venting
I've got a vented gas cap, yet whenever I open it there's a good amount of pressure. Are they really supposed to build up a lot of pressure before they vent?
It's a '71 non-EEC system. Thanks!
71 K20 64 GMC mud truck |
05-19-2013, 08:50 PM | #2 |
Re: Gas cap not venting
I don't know what the factory spec was, but my locking cap is vented.
05-19-2013, 09:16 PM | #3 |
In warmer weather with the tank about 3/4 full I get a little sigh of pressure when I open mine.
FWIW I had a locking vented cap, but it leaked like crazy turning right. Bought a vented non-locking cap from Brothers and no more leak. Cap has only been on there a couple of weeks, but so far I'm happy.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
05-20-2013, 05:11 AM | #4 |
1971 from the factory were nonvented gascaps// the gastank vented thru the charcoal cannister thru the carb
sounds to me that somebody that doesnot understand the venting concept changed things any pressure buildup means u either have a defective vented cap or a stock nonvented cap search this forom this has been covered hundreds of times
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-20-2013 at 05:32 AM. |
05-20-2013, 06:43 AM | #5 | |
05-20-2013, 08:26 AM | #6 | |
I've been through this with the EEC before, and my truck doesn't have ANY emissions junk on it. It's not a stock cap, it's the 67-70 vented cap from Classic Parts And that is correct about 3/4 tons not having EEC.
05-20-2013, 08:43 AM | #7 |
i'm sure nuttin has been changed in 45years
fact is you either have defective gascap or wrong gescap those are the reasons you will have pressure change to a working vented cascap to solve problem
05-20-2013, 09:42 AM | #8 |
There's a reason (many) gas caps state "caution when opening". Some pressure difference from outside is normal.
05-20-2013, 11:40 AM | #9 |
I have a 71 GMC with Calf Emmission Crap, IE charcoal canister! I rebuilt the entire fuel system over the winter. New tank,sender, New non-vented cap from NAPA. Now when I crack the cap there is a lot of built up pressure in tank ? Any help in figuring this out would be appreciated ?....Thanks
71 C-20 07 Magnum RT AWD |
05-20-2013, 01:45 PM | #10 |
I've been buying locking caps from the local Cdn Tire. They are not vented and on hot days you can smell fumes on occasion if the gasket is not seated properly. I usually buy a couple caps at a time because the gaskets rot, last maybe a year or two. Get the smallest drillbit you can find (I use 1/16") and make a hole, venting problem solved.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
Thread Tools | |
Display Modes | |
