Old 05-20-2013, 07:18 PM   #1
ApacheKid
ApacheKid's Avatar
1965 C10 283 c.i. Power Glide
OK, first want to introduce myself to this forum. I have recently accepted, as a gift, my grandfathers 1965 C10 Chevy Pickup. Problem? I was unassembled! No, really! I am one part away from completing the assembly. That is where I need help. On the powerglide transmission there is a linkage connection that I can best discribe as a ball and joint. I have the linkage but for the life of me I can't determine how/where this linkage goes. This in not the main linkage from the steering column to the shift lever. It appears to be a secondary linkage (again with ball and joint) that bolts somewhere with two bolts. Can't be far from the transmission because the linkage is not too long. Can someone help me?
ApacheKid is offline   Reply With Quote
Old 05-20-2013, 08:04 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: 1965 C10 283 c.i. Power Glide
It goes here
LT1 Burb is offline   Reply With Quote
Old 05-20-2013, 08:04 PM   #3
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wrong Post
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 05-20-2013, 08:10 PM   #4
ApacheKid
ApacheKid's Avatar
Sure enough. Problem? Where on the carb does that connect. I assume that this is an activation for power down shift upon heavy acceleration.
Old 05-20-2013, 08:31 PM   #5
ApacheKid
ApacheKid's Avatar
This would have been a better time to install that control arm. Dang!!!
Old 05-20-2013, 09:47 PM   #6
LT1 Burb
LT1 Burb's Avatar
Here on mine but there should be a spot on the 4 barrel linkage on yours, and yes it is the kickdown linkage.
Old 05-21-2013, 12:21 AM   #7
WhippinSaw
WhippinSaw's Avatar
I Like the motor, post some more pics of your project. I bought that linkage aftermarket here. http://www.classicparts.com/1963-71-.../#.UZr1iBEo76c And made custom linkage for my holley carb here.http://www.fordmuscle.com/archives/2...rottleLinkage/
WhippinSaw is offline   Reply With Quote
Old 05-21-2013, 12:30 AM   #8
LT1 Burb
LT1 Burb's Avatar
Are you interested in selling your stock linkage, I need the lower tranny piece that is close to 12" long.
Old 05-21-2013, 09:56 AM   #9
WhippinSaw
WhippinSaw's Avatar
Stock linkage broke, replacing modified linkage.
Old 12-20-2013, 05:35 AM   #10
pimpston65
pimpston65's Avatar
i noticed a brass fitting on your carb, and a fitting that attaches to the threaded spot on the back of the intake, my question is what connects to them?
pimpston65 is offline   Reply With Quote
Old 12-20-2013, 10:28 AM   #11
LT1 Burb
LT1 Burb's Avatar
The big one is for the PCV line which attaches to the block where the old draft tube went and the small one is the vacuum line from the transmission.
Old 12-20-2013, 01:40 PM   #12
pimpston65
pimpston65's Avatar
thank you so much, i have the tube at the back of the block, so should i just leave that part on the carb blocked off? also the little one goes to the module on the trans right?
Old 12-20-2013, 06:12 PM   #13
LT1 Burb
LT1 Burb's Avatar
Yes and Yes
Old 12-20-2013, 06:24 PM   #14
pimpston65
pimpston65's Avatar
thanks a ton. enjoy ur holiday
Thread Tools
Display Modes
