Old 05-23-2013, 06:17 AM   #1
kbar
exhaust
I getting ready to start planning/buying parts for a LS conversion in my 1975 C10. I am wondering whats the best exhaust set up to help my engine breath(pipe size, x or h joint, muffler, etc), I would REALLY like to do true duals. What you guys recommend?
kbar is offline   Reply With Quote
Old 05-23-2013, 08:48 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: exhaust
I have 2.25" on my stock 4.8 in my 65, I have true duals also.
It really depends on what your motor is set up for. if you have a 4.8/5.3 stock with headers and a tune, 2.25/2.5" would be fine.
If you have a 6.0+ with cam, headers tune, 2.5" would be minimum. 3" would be best I think.
If you have it juiced or turbo, then 3" would be best, IMO.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-23-2013, 12:55 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: exhaust
^^^ looks about right. My 6.0 has 3" tru duals...tho I plan to add an H and would run an X if there were room.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-23-2013, 01:02 PM   #4
Jon01
Jon01's Avatar
Re: exhaust
My built LQ4 will run dual 2.25" only because I'm running the exhaust that was on the truck already since it matches the rest of the appearance.
Once I change it I will run dual 2.5" or a single 3, haven't decided.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 05-24-2013, 01:05 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: exhaust
I"m running 2.5" true duals with just a pair of magnaflow bullet muffler/resonators in. It works fine, but with my lq4 modded it ends up being a bit restrictive because a) its only 2.5" and it could use a bit more breath, and b) its not mandrel bent and the exhaust has some turbulence in a few places.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-27-2013, 02:33 PM   #6
Billett
Billett's Avatar
Re: exhaust
I run a 2.5" true dual set up with an x pipe on my stock 350, but I'll be using the same setup on my 6.0L. The hard core guys will tell you that 2.5" is too big for this size motor but when you figure in crush bends it evens out. Even with mandrels the power loss is insignificant unless you are going for a full track vehicle.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 05-27-2013, 02:36 PM   #7
Billett
Billett's Avatar
Re: exhaust
BTW I use a pair of flowmaster super 44s with no cats. If I didn't just buy the setup Id probably go with hooker max flows. I also just bought the Doug thorley tri-y's. Can't wait to see what they sound like.
Will
2024 Toyota Sienna
Thread Tools
Display Modes
