Old 05-27-2013, 03:07 PM   #1
dkauffman05
dkauffman05's Avatar
Lq4/700
I bought a lq4 from a Denali and when I got it the engine didn't have the flex plate with it. Nw I know it would have had a 4l65 behind it. I'm putting a 700r4 what's the best rout for me to go since I don't have a flex plate at all ?
dkauffman05 is offline   Reply With Quote
Old 05-27-2013, 04:26 PM   #2
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: Lq4/700
Flat 6.0l/4l80e flexplate with the spacer.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 05-27-2013, 07:26 PM   #3
dkauffman05
Re: Lq4/700
Spacer before or after the flexplate. Would the flexplate that came with a lq4/4l65 be flat kr dished?
Old 05-27-2013, 10:22 PM   #4
softballnrd27
Re: Lq4/700
I am not sure on the 4l65e flexplate.
Spacer goes between the crank and the flexplate.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 05-27-2013, 11:26 PM   #5
85burb
85burb's Avatar
Re: Lq4/700
I have used advanced adapters kit for both of my swaps.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-28-2013, 09:27 AM   #6
thump16
thump16's Avatar
Re: Lq4/700
i am running 04 lq4 with a 97 4l60e converted to 4l65e and all you need is to purchase a stock 6.0 flywheel which is very similar to a th400 flywheel. it has the spacer built into it which will allow you to run an older style tranny without having to buy extra parts you will use 700 torque converter just make sure you elongate the holes slightly on the flexplate to allow bolt up of flexplate to torque converter. There is a thread on here with that minor mod detail.
thump16 is offline   Reply With Quote
Old 05-28-2013, 04:55 PM   #7
softballnrd27
Re: Lq4/700
I didn't have to enlongate the bolt holes but I do have an aftermarket torque converter.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 05-28-2013, 07:05 PM   #8
dkauffman05
Re: Lq4/700
So if i just buy a 6.0 flexplate that will bolt right up, should i get the flexplate that came with my motor and 4l65 or a flexplaate from a 4l80 ?
Old 05-29-2013, 12:36 AM   #9
thump16
thump16's Avatar
Re: Lq4/700
yes the flexplate that came with the motor will be fine.
Thread Tools
Display Modes
