Old 06-02-2013, 11:12 AM   #1
BigRed76
BigRed76's Avatar
Anyone know their alignment angles?
I'm just curious what guys are running their alignment angles at on their trucks. I just lowered mine yesterday, and the alignment specs called for 0.25* camber on both sides, 0.38* total toe, and the machine didn't give me a caster spec. I didn't like either of those specs, but right now mine is set at -1.1* camber left & -1.2* camber right, 2.7* caster left & 3.3* caster right, and 0.16* total toe. The only thing I adjusted after the drop was total toe. I figured I'm getting new tires soon so I might as well run those camber numbers and see how it does, if it doesn't work out then I'll change camber when I get new tires.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-02-2013, 11:19 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Anyone know their alignment angles?
Here's a thread on this.I assume BMERDoc is better versed in alignment than I am.Seems he found some info within the machine he uses.
http://67-72chevytrucks.com/vboard/s...d.php?t=582187
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-02-2013, 11:33 AM   #3
CastIron
CastIron's Avatar
When I aligned my stock height pickup, I set the camber to -.3, caster to +1.6 and the toe to slightly in. It drives nice and the steering wheel centers itself perfectly coming out of a corner.
You might have a little too much camber in yours. That may start to wear the inside edge of the tires. Your caster should be fine, it doesn't affect tire wear. More positive caster generally makes the steering wheel a little harder to turn, but makes it center itself better and more stable at higher speeds.
I'd just run it and see how thing wear and how it drives. It looks like it would be pretty good.
CastIron is offline   Reply With Quote
Old 06-02-2013, 11:46 AM   #4
Wrenchbender Ret
In set my 70 stock height Stepside at +1 degree caster. -1/8 degree camber & 1/8 in. toe in.
It drives excellent.
Wrenchbender Ret is offline   Reply With Quote
Old 06-03-2013, 08:30 AM   #5
BigRed76
BigRed76's Avatar
I think I'll probably end up changing my camber to -0.3 - -0.5 because when I make sharp turns in a parking lot it makes one tire sounds like its scrubbing across this ground.
Zach
Thread Tools
Display Modes
