Old 06-03-2013, 02:48 PM   #1
Operatorfailure
What oil pan for a lowered ls swap?
I plan on lowering my truck soon and am swapping a 5.3 in that has a cracked pan, so I figure I might as well get one with more ground clearance. I have seen quite a few people that have commented on the truck pan hanging below the crossmember, just not many saying what pan they went with to fix the issue. I have heard of people using f-body pans, h3 pans and aftermarket pans also, does anyone have first hand experience with any of these?
Operatorfailure is offline   Reply With Quote
Old 06-03-2013, 02:56 PM   #2
nlped
nlped's Avatar
Re: What oil pan for a lowered ls swap?
I'm using a CTS-V pan & I'm lowered /c bags. It sits slightly higher than the stock k-member.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-03-2013, 05:38 PM   #3
Daaaanz67
Ctsv here also
Daaaanz67 is offline   Reply With Quote
Old 06-04-2013, 09:49 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
I have a NoLimit crossmember with the Fbody pan. Fits awesome, tons of clearance
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-04-2013, 10:26 AM   #5
66C06
66C06's Avatar
camaro/trans am ls1 oil pan, pickup tube and windage tray. It's the lowest profile and will give you the most clearance (even more so than the "GM hot rod swap pan"). you can also do a canton or moroso ls1 F-body pan (street/strip version, standard capacity) if you want to look pretty.
66 SWB Stepside: Project C-O6
06 ZO6 MSM 6spd 562/520rw N/A
06 Caddy CTS The Daily
07 Hayabusa - absolute chaos
66C06 is offline   Reply With Quote
Old 06-04-2013, 11:16 AM   #6
ChevyCruizer
17's too small
ChevyCruizer's Avatar
You definately DO NOT want the GM hot rod pan, that is basically the stock GM truck pan and it hangs way down low.
The F body is over an inch shallower in the sump than the CTVS, but the sump is longer.
Some good threads here, hereand the best one here with all of the pictures and measurements.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 06-04-2013, 12:32 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The hot rod/lh8 pan isn't the truck pan, and I can tell you this because I'm staring at it under the bottom of my truck. The lh8 pan is still larger like the truck pan but has a different profile, sits shallower, but does fit lowered trucks just fine. The difference is that instead of hanging 1.5-2.5" below the xmember, it hangs about even with or a tad higher than the crossmember, depending on which perches and mounts you run.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-04-2013, 01:30 PM   #8
JNJchev77
Registered Cruiser
JNJchev77's Avatar
^ x2
I'm running extreme PB front and rear, with the Hotrod pan, only about 5/8 below the crossmember, not a bad fit at all. It is definitely not the truck pan.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 06-04-2013, 02:08 PM   #9
Wasted Income
Boosted Member
Originally Posted by JNJchev77 View Post
^ x2
Judging by the pic in your sig, I wouldn't want it even a c-unit hair below the crossmember.
But that's just me.
Turbo diesel
Old 06-04-2013, 03:52 PM   #10
JNJchev77
Registered Cruiser
JNJchev77's Avatar
But that's just me.
Ehh, comes with the territory I suppose, just gotta pay attention while you drive (not you specifically), no texting or net surfing.. or eating a bowl of cereal (saw that one the other day). I am extra cautious even in my daily, so no big deal to me I guess. I only drive it extremely low on roads that I'm familiar with.
Anyway, if you're running stock suspension or running a mild drop, this pan will be just fine, imho.
77' Chevy SB
5.3/4l60e combo
Old 06-04-2013, 04:10 PM   #11
Wasted Income
Boosted Member
No...you're right. ME specifically. I busted up my stock truck pan not once, but twice with my 69 on bags. Stupid crowned roads.
lol
Turbo diesel
Old 06-04-2013, 04:49 PM   #12
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Lol... I've seen it happen, so you're not alone...
77' Chevy SB
5.3/4l60e combo
Old 06-04-2013, 08:22 PM   #13
crazy longhorn
Fabricate till you "puke"
I picked up the GM hotrod pan(basically h3 hummer pc). For my app, lowered , but not slammed, it should fit the bill. Also less than $150, with pan/gasket/tray/hardware & dip tube? The 5.3 is not across the rails yet, but my bet is about even with the crossmember, or 1/2" below. That will work on a 3/5 drop, with 1 1/2" body drop (no taxes on the body drop) Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-04-2013, 08:28 PM   #14
Operatorfailure
I can pick up an f body pan for $200 with everything, gasket, bolts, pickup tube, dipstick and all so I'm just going to do that. I would like to see a pic if anyone has the hot rod pan since I'm probably going to swap a 5.3 into my dads 66 in the next year or so.
Old 06-05-2013, 08:20 AM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The GM Hotrod pan is $169 from Summit!
http://www.summitracing.com/parts/nal-19212593
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-05-2013, 10:06 AM   #16
Operatorfailure
I have trashed one pan from it hanging just below a crossmember in my trans am, I would rather pay a tad more and not worry about my pan hanging low. Thanks for the link though, I'm sure it will come in handy for people.
Old 06-05-2013, 10:13 AM   #17
crazy longhorn
Jegs has the pan kit, for $146....Longhorn
Thread Tools
Display Modes
