Old 06-05-2013, 05:40 PM   #1
ShinyC10
Turbo
Does anyone know anything on the t3/t4 turbo kit? Is it crap or solid? Please help! And any suggestions on good turbo kits around the same price range (give or take a few bucks)?
ShinyC10 is offline   Reply With Quote
Old 06-06-2013, 01:49 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Turbo
What kit? And a t3/t4 is a hybrid type turbo many many versions of that type and trim and a/r ratios. Ranging good to crap
Based off your question you should prolly spend a couple weeks researching turbos.
But stay away from internal waste gate and solid bushing\bearing style (eBay turbos). They work for a few months then you need new ones.
Stainless steel for headers is a great idea and quality will save you headache
Look into the wrench rat system and banks turbo kits. Those prices are what your going to expect for a durable setup
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-06-2013, 04:23 AM   #3
Jabes1
Jabes1's Avatar
Re: Turbo
There is nothing wrong with internal wastegates nor journal bearings. Journal bearing center cartridges are rebuildable where as most ball bearings are not or simply just as expensive to rebuild as buy new. I've rebuilt a few journal center cartriges in my day and its surprisingly simple. Most turbo's are component balanced and for extra caution ...if you index while under disassembly no real need to have it balanced again. Some people will argue that, but the 20g in my Impreza is real life proof with 30k on it and still going strong after a home rebuild. The 20g is a journal bearing center cartridge with an internal gate. No problems there. Most factory turbo setups are internally gated for simplicity and compactivity. Heck... a lot of Semi's use journal bearing center cartridges.
External wastegates allow for more precise boost control with less chance of boost creep or staying partially closed. Internal gates are more cost effective where external are more expensive.
You would be better off doing a lot of reading and fabbing your own kit. Lots of ways to accomplish a turbo setup cost effectively. These trucks are perfect for front mount intercoolers. After my tune is finished or solid enough I will be doing a front mount intercooler (FMIC), Large single twin scroll, externally gated, blow off valve recirculated back to the intake (so it doesn't sound like I have bird chirping when shifting or lifting), bigger injectors and some form of electronic boost control (EBC), Stock ported exhaust manifolds plumbed to the twin scroll. I may end up with a manual boost controller (MBC) because they are cheaper than EBC's. Ideally though the EBC.
Google is your friend, lots of good books on it too. Take a stroll over to Barnes and Noble... quite a few good books in stock. Don't just throw a bargain turbo at your truck. Lots of variables to gamble with... turbo could be to big/small, not efficient in the range your looking to use it in (learn to read compressor maps).... you could have the wrong cam and so on and so forth. Read my friend.
Jabes1 is offline   Reply With Quote
Old 06-06-2013, 06:31 AM   #4
wraprail
wraprail's Avatar
Re: Turbo
Hey I been to Victorville!!
Yay Bob's Tire Service!!
Awalys have to drive the fast lane on Interstate 15 where it crosses D street/RR tracks with the left fender 2" off that center wall and foot to the floor.
Fun drive.
But seriously, great turbo info. Thanks for posting.
wraprail is offline   Reply With Quote
Old 06-06-2013, 11:02 AM   #5
Mikec10
Mikec10's Avatar
Re: Turbo
Read all of this
http://www.theturboforums.com/knowledge.php
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 06-06-2013, 01:27 PM   #6
tinydb84
tinydb84's Avatar
Re: Turbo
the turbo forums are great and you can also check out the forced induction section on the ls1tech forums
David
Instagram: myfabguy
Old 06-07-2013, 12:40 AM   #7
andrewmp6
Re: Turbo
Just don't buy a cheap ebay kit from sx power aka ss auto chrome.
andrewmp6 is offline   Reply With Quote
Thread Tools
Display Modes
