Old 06-26-2003, 10:32 PM   #1
cbeebe
Newbie questions
Hi all -
Just picked up a '67 GMC longwheelbase. I think it is all original....the numbers on the engine and tranny match what is in the glovebox. It has the 305E with the 3 speed. I've been plinking around trying to find a good resource to decode VIN and paintcodes to make sure that everything is copacetic but can't find the info. VIN is CM1590DCxxxxA, paint code is 557AA.
Does anyone have the info for this or point me to the right place?
Also, is there a contact at GM where I can order the original build info? Any other nobrainer resources I should know?
Thanks for any and all help.....
Curtis
cbeebe is offline   Reply With Quote
Old 06-26-2003, 10:36 PM   #2
krue
Designated A-hole!
krue's Avatar
Welcome to the board from Mississippi!
I know we where talking about this somewhere, I'll look and see if I can find the GMC decoder.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-26-2003, 10:42 PM   #3
krue
Designated A-hole!
krue's Avatar
I couldn't find it but I believe Longhornmail has it. I am sure he'll help you out!
www.daveramsey.com
Old 06-27-2003, 12:01 AM   #4
Hutch
Hutch's Avatar
Welcome to the board from the big state of Texas
Here is a link to GMC Pauls web-site that will help with the Vin #
GMC Pauls GMC Data
Here is a link to the standard production colors for 1967 GMC
Autocolorlibrary GMC 1967
There were special orders also. Some will be listed under the DSO
box on the glovebox data sheet. (Dealer Supplied Opton)
There is quite a bit of data on this subject in the board archives but for the time being the search option is disabled.
When it becomes available again give it a try.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 06-27-2003, 04:36 AM   #5
wHATANERD
wHATANERD's Avatar
Welcome again from the great state of Texas
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 06-27-2003, 07:26 AM   #6
cbeebe
Thanks for the warm welcomes. I'l check out the referenced sites to see what I see.
I'm sure I'll be in touch.
One other question. Is there a "Bible" restoration for these trucks? There are a couple of minor items that I'll need to restore to original (like the black painted trim on the chrome grill) and I'd like to see how it originally looked.
thanks again,
Curtis
Old 06-27-2003, 09:26 AM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
GMCPaul (aka Paul Robbins) would be you GMC Bible. Not sure what printed material there is though. He is a hard man to contact and is at The Carlisle PA show through the weekend. Go to www.gmcpauls.com for contact info.
As for your grille, I don't think the correct 67 grille had any black accents on it except for the lettering (maybe this is what you are referring to). The 71/72 grille certainly did, maybe someone swapped? The 67 grill is a one-year-only item and should have GMC stamped in the center and your hood should be void of emblems/lettering.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-27-2003, 10:36 AM   #8
cbeebe
That's how it looks....I assumed that the "GMC" or other accents were painted at one time but that's what I get for assuming.
Thanks again...I'll try to get hold of Paul after Carlisle.
C
Old 06-27-2003, 01:55 PM   #9
cbeebe
C
Old 06-27-2003, 05:00 PM   #10
Welcome to the board from the very soggy southern Mississippi.
Old 06-27-2003, 06:45 PM   #11
68 Stepside
huh?
68 Stepside's Avatar
Welcome from a fellow Tampa resident!
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-29-2003, 07:55 AM   #12
cbeebe
Couple of problems...
thanks again for all the kind words...
After driving the truck for a couple of days, I've found two problems:
1) the old Stromburg carb doesn't seem to hold any fuel in it's bowl overnight. It will start on the first try all day long but once it sits overnight I've got to pump the pedal about 30 times to get any fuel to it. Looks like someone has installed a checkvalve in the fuel line between the pump and the carb to keep gas from draining out, but it still does overnight. Any thoughts?
2) Sometimes it is very difficult to get the 3-speed tranny in reverse, and yesterday I had a hard time getting it into first, too. I can usually fiddle around with putting it in neutral, then another gear, then nursing it into reverse but occasionaly I have to turn off the engine, put it in reverse, then restart it. I't isn't binding, just grinding the gears. I know reverse isn't synchro, but it shouldn't be THAT tough. The other gears are fine and the clutch seems fine...no creep, no slippage. It has the factory HD clutch, I think.
Let me know any ideas.....
Curtis
Old 06-29-2003, 10:26 AM   #13
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Sounds like your clutch isn't disengaging completely. Or you aren't pushing the pedal far enough down. If it's a new clutch, try readjusting it so it will disengage with the pedal closer to the top.
Congrats on your new purchase, and welcome to the board!
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 06-29-2003, 10:32 AM   #14
formerfordguy
72 GMC SWB
formerfordguy's Avatar
welcome in kind of new here but welcome.
formerfordguy is offline   Reply With Quote
Old 06-29-2003, 02:23 PM   #15
Chevy4Life
Chevy4Life's Avatar
Welcome from Vegas. Good Luck with the new truck.
Chevy4Life is offline   Reply With Quote
Thread Tools
Display Modes
