Old 06-08-2013, 11:51 AM   #1
Andrewman
Cooling Fan question
Hello all,
I have a 1970 Chevy C20 that I am slowly restoring. I would like to install a thermostatic fan clutch in place of the flex blade fan. The engine is a 350.
My question is, will I need an engine fan-to-water pump spacer with a fan clutch to position the fan in the shroud correctly?
Currently, there is a approx. 2.5 inch spacer on the flex fan in my truck.
I am planning on ordering a 6 blade fan and standard duty thermostatic fan clutch.
Any photos would be great.
Thanks in advance!!!
Andrewman is offline   Reply With Quote
Old 06-08-2013, 11:55 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Cooling Fan question
On my 72 c10 with a 350 a p. O. Replaced the fActory clutch fan with an aftermarket flex fan. I found a factory clutch and fan on the parts board. The spacer is part of the clutch. I don't think the 70 trucks had a clutch fan but I don't see why a 72 wouldn't work. Not sure if 71 had them or not. Just be sure to ask for same engine/ trans and Ac or non Ac. You can also buy them new.
WIDESIDE72 is offline   Reply With Quote
Old 06-08-2013, 12:16 PM   #3
FirstOwner69
FirstOwner69's Avatar
My early 69 3/4 ton with A/C (HD cooling) came new with a clutch fan. No spacer needed.
FirstOwner69 is offline   Reply With Quote
Old 06-08-2013, 03:26 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My '72 K20 has an OEM clutch fan. There's a short shaft from the mounting plate to the clutch unit (all one piece)... no additional spacer.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-08-2013, 04:57 PM   #5
Andrewman
Smile Re: Cooling Fan question
Thank you, your replies have all been very helpful.
Old 06-08-2013, 06:36 PM   #6
ole dollor
ole dollor's Avatar
you should be able to get a fan and clutch off of almost any gm pickup or car and make it work i do think some fans are a little bigger than others , seams like some are 15" and some maybe 18" . as long as it does not hit the shroud, just leave off the spacer. some also have more blades than others...like 5 blade and 7 blade ...
ole dollor is offline   Reply With Quote
Thread Tools
Display Modes
