Old 06-12-2013, 07:41 PM   #1
Hotrod1979
64 C10 longbed two or one piece axle with 383 stroker engine
HI
I have a 64 c10 longbed with a strong 383 stroker engine and th700r4 tranny.
My original drive shaft set up is a two piece drive shaft with upper mount bearing. Now that I put in the th700 transmission my front drive shaft is to long.
I have read a lot about one versus two piece drive shafts but I am still not sure what the best option will be.
My upper mount center bearing is the weaker one and I have the thinner front drive shaft. My truck is lowered 4" in the back. Will a one piece axle work without interfering with the crossmember or should I stay with my two oiece acle and just shorten the front piece.
I am a little worried about it because I have not got the heavy duty lower mounted support bearing and thicker front shaft.
Any advice from you guys? Thanks a lot
I live in the Netherlands so getting parts such as a bracket for a lower mount center bearing is very difficult....
Hotrod1979 is offline   Reply With Quote
Old 06-12-2013, 09:22 PM   #2
66 C10 383
Re: 64 C10 longbed two or one piece axle with 383 stroker engine
Though I don't have an answer for you, I'm in kinda the same situation. I'm currently building a 66 C10 LWB and will be running a stout 383 with a T56 6 speed tranny.
In my research I've been told that the 2 piece driveshaft is actually stronger than a long single driveshaft due to the length. I guess it's the torsional twisting of the longer one that is the concern.
As far as the bearing support, I'm interested to see some replies too.
66 C10 383 is offline   Reply With Quote
Old 06-13-2013, 04:24 PM   #3
Hotrod1979
Does anybody know what the maximum outside diameter can be for a one piece driveshaft on a longbed 64 c10 and still have enough clearance with the crossmember? And what is the maximum amount you can lower a truck with a one piece axle?
Old 06-13-2013, 05:26 PM   #4
creep
Registered Loser
creep's Avatar
I don't have any problems with my 2 piece driveshaft and 383 stroker (405hp). My carrier bearing mounts on the bottom though.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-13-2013, 05:42 PM   #5
Hotrod1979
Problem is that my slip yoke has far too much play. And finding a replacement drive shaft here in the Netherlands is very difficult. That is why I was thinking about replacing the whole shaft for a one piece.
The overall length of my drive shaft would be 66". A 3.5" od driveshaft can have a maximum length of 65".
The question is what the maximum outside diameter is a 64 longbed can have to still clear the crossmember..
Old 06-13-2013, 08:23 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Have you looked online for some places to build you a custom drive shaft?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-14-2013, 03:19 AM   #7
Hotrod1979
No I went to my local shop. Building a one off with new slip yoke will get far to expensive. Around 750 euro, that is about 900$.
Old 06-14-2013, 04:31 PM   #8
Hotrod1979
today I measured what clearance I would have between a 3.5" thick one piece driveshaft and my crossmember. Because the yoke on the diff is not centered the clearance between de driveshaft and crossmember on the right side is only 5/16" That's can not be enough....
Old 06-17-2013, 01:16 AM   #9
luvbowties
luvbowties's Avatar
Question Re: 64 C10 longbed two or one piece axle with 383 stroker engine
Almost sure I recall someone enlarging that opening and re-inforcing the x-member. Maybe Google will help.
Why can't you just shorten the tranny-end of your 2-piece shaft & use the bearing & slip-joint as is?
Sam
luvbowties is offline   Reply With Quote
Old 06-17-2013, 02:38 AM   #10
Hotrod1979
My slip yoke has far too much play to allow the shafts to be balanced out correctly..
Old 06-18-2013, 12:35 AM   #11
Captainfab
60-66 Nut
I would stay with a 2 piece driveshaft in a long bed. Do you have wrecking yards that would have some GM trucks from in the 70's and 80's? You should be able to find a driveshaft(s) from one of those that can be made to work. You can typically have a driveshaft shortened much cheaper than having one lengthened, or a complete new one built. And while at it I would upgrade to the HD center support bearing.
I believe I have some fairly good stock HD driveshafts, but I imagine shipping to The Netherlands would be expensive.
Thread Tools
Display Modes
