Old 06-17-2013, 03:48 PM   #1
jtrichard
63 c20 6.2????
hi guys i have a 63 C20 long fleetside looking to put front disc and maybe 6.2 turbo i have a 82 2500 GMC with 6.2 i am thinking (that might be a bad thing lol)of taking the front cross member complete and power steer gear and use hydro boost THATS the front now i want to stay with the 4 speed muncie (granny) so i can get some kind of freeway speed out of it i am leaning to changing out the rear end .......the donor truck has auto trans ...cant find build sheet ....i dont think it is 700r4 also dont know ratio yet of rear any one here done any like this? looking for ideas THANKS Richard
jtrichard is offline   Reply With Quote
Old 06-17-2013, 04:21 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 63 c20 6.2????
Just change the spindles/upper and lower a-arms, steering linkage, pwr steering and then put the 6.2 in there. I am not sure the 4 speed will bolt up though.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-17-2013, 04:24 PM   #3
tincan1966
tincan1966's Avatar
Re: 63 c20 6.2????
I'd swap in the '82 trans and rear end too- might as well keep the matched set. Won't really take much fab and you have a complete parts truck to use. Just my opinion.
Good luck and sounds cool no matter which way you go.
tincan1966 is offline   Reply With Quote
Old 06-17-2013, 05:18 PM   #4
luvbowties
luvbowties's Avatar
Question Re: 63 c20 6.2????
Doesn't that 4-speed still have just a 1:1 inout/output ratio in 4th gear? If so, won't help much with higher speeds on freeway--rpm's will be high at freeway speeds when using a numerically high diff'l ratio.
Sam
luvbowties is offline   Reply With Quote
Old 06-17-2013, 08:38 PM   #5
gofastnut
gofastnut's Avatar
Re: 63 c20 6.2????
X2
Use your 82 as a donor, if it's in good shape chassis wise. Take everything you need off of it.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 06-17-2013, 09:19 PM   #6
jtrichard
Re: 63 c20 6.2????
yes the trans is 1to1 in 4th.... looking to put in rear with 3.73 or better yet 3.42 i am staying with man. trans.... Bolt up of trans should not be a problem after all its a chevrolet NOT a F%*D (nasty four letter word)
Old 06-17-2013, 10:01 PM   #7
jtrichard
Re: 63 c20 6.2????
[QUOTE=Clyde65;6128089]Just change the spindles/upper and lower a-arms, steering linkage, pwr steering and then put the 6.2 in there. I am not sure the 4 speed will bolt up though.[/QUOTE
Clyde why not use the whole crossmember so i dont have to pull it all apart?
Old 06-18-2013, 12:39 AM   #8
jtrichard
Re: 63 c20 6.2????
donor truck has TH400 trans and 4:10 rear gear ...so i have other rears with 3:73 atleast ...havent looked yet what are thoughs on changing to the rear leaf springs out of 82?
Old 06-18-2013, 01:44 AM   #9
Corts60
Just here to tinker
Corts60's Avatar
Re: 63 c20 6.2????
I think you should put in 3.42 if you have them. That set up with the 6.2 should yield you around 18-22 MPG.
Old 06-18-2013, 01:55 AM   #10
jtrichard
Re: 63 c20 6.2????
if i can find one that is what i want to use is a 3:42 ....i cant belive the 82 has th400 with 4:10 from factory
Old 06-18-2013, 07:51 AM   #11
Clyde65
Clyde65's Avatar
Re: 63 c20 6.2????
[quote=jtrichard;6128708]
Its just easier to put in what you need and not do the whole cross member ( this is only my opinion). and you can put new parts in while you do it, tie rods, bushings etc.
Clyde65
Rebuild of Clyde
support our troops!
Thread Tools
Display Modes
