need help for interior rubber
I just got some interior rubber parts from Classic Heartbeat, but have questions on how to install. First off, I got the two rubber bumpers for the ashtray and two for the glovebox, but I cant tell which is which. Two are kind of flat and two are kind of pointy.
Next, I got rubber weatherstripping for the doors. Each one is a long strip, with one sharp 90 degree bend. Where does the 90 degree bend fit? What is a good glue to use? How should I prep the paint before I glue? The interior is temporarily painted with rattle can primer covered by rattle can shiny - but "temporary" could be another 5 years. I'm hoping the weatherstripping will keep the doors a little tighter and reduce some of the rattling, so don't want to wait years until I do a final paint on the cab before installing to rubber. I'd call Wes at Classic Heartbeat, but I think he's on vacation and just has someone helping him with shipments. Thanks for the help.
1967 GMC 1500 SWB. Driving this truck since I was 14. |
Moderator
![]() Join Date: May 2007
Re: need help for interior rubber
Flat are for the ashtray, pointy for the glovebox
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
What leddzepp said and the 90 degree bend goes in the corner at the top of the door opening before it bends down along windshield. I used 3M yellow adhesive to glue mine in.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
3-m yellow works fine...but you're not getting it back off without destroying the rubber and paint...maybe look into the push on stuff like GMC Paul and others sell...think it may be a later dodge part
Thanks for the info. With the window rubber corner at the A pillar, the ends will meet under the door sill, correct?
Any ideas on a less permanent glue then 3m yellow? I've already bought the rubber, so will be using what I've got. Thanks!
Thread Tools | |
Display Modes | |
