Old 06-23-2013, 04:13 PM   #1
sKnNyPpY
sKnNyPpY's Avatar
Where does this brown wire plug in?
Hi guys, I have all new battery, alternator, regulator, positive and negative terminals and wires to alternator bracket and starter respectively, and a new HEI. I'm not getting a charge from my alt and drain the battery after jumping and running any electrical such as wipers/ a/c. After tracing all the wiring all I can find is this brown wire and connector unplugged (to regulator?) and a green wire that has some kind of insulation around it cut off riding along with the old yellow and purple from the starter. Thanks, she's almost there!
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 06-23-2013, 04:38 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Where does this brown wire plug in?
I am curious about this wire also. I don't believe it has anything to do with the charging circuit. My truck has the external voltage regulator and I have no problem with charging. The green wire you mention may be for the temp sender?
TBONE1964 is offline   Reply With Quote
Old 06-23-2013, 04:47 PM   #3
kaynnon
kaynnon's Avatar
it goes to a solenoid that controls the vacuum advance, its a transmission spark solenoid. part of emission crap. wont effect you any
72 Cheyenne LWB
kaynnon is offline   Reply With Quote
Old 06-23-2013, 04:49 PM   #4
sKnNyPpY
sKnNyPpY's Avatar
Thanks guys...now if I could just get a charge!
Old 06-23-2013, 05:54 PM   #5
BigRed76
BigRed76's Avatar
One thing you should check with your charging system issue...the external voltage regulator has to have ignition power from your ignition switch (don't remember which color wire on the regulator) so if something is wrong with your ignition switch it might not be giving your external voltage regulator that ignition power that it needs. We had that problem happen on my dad's '69.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-23-2013, 06:00 PM   #6
sKnNyPpY
sKnNyPpY's Avatar
Thanks big red, I think that is the brown wire...just not this brown wire. Gonna redo all the grounds and if that doesn't do it check out the ignition switch
Thread Tools
Display Modes
