Old 06-29-2003, 02:46 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
power brake set-ups
The PO had power brkes installed and I'm wonder if he used the right MC. With all drums shouldn't the two "wells" of the MC be the same size? Also when applying the brakes w/ 4 drum set-up the size of the MC rod determines the amount of pressure to the front and back, right? Anybody have pics of theirs that was original power brake booster/mc w/ 4 drums?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-29-2003, 03:57 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
I put a disc brake Dana 44 under my truck but the MC and booster are all still original on my truck. I will take pics tomorrow and post pics here.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 06-30-2003, 07:12 PM   #3
Cal69Chevy
Cal69Chevy's Avatar
You can check out my setup here:
Click Here.....
Ken
'69 Chevy, 4X4-SB 350 TBI-TH350 Trans-205 Transfer Case-Dana 44 Front-14 Bolt Rear-Front Disc Brakes-Factory A/C-P/S
Ken's '69 Page
Cal69Chevy is offline   Reply With Quote
Old 06-30-2003, 08:02 PM   #4
Mudder
Mudder's Avatar
The 2 wells are the same size (small) on the 67 power brake setup with drums. I'm still using the same set up since 86 now with mine and have had no problems. Im running all disks now.
Mudder is offline   Reply With Quote
Old 07-01-2003, 05:13 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks. After seeing Kens mine is definetly not the large and small well MC. Ken what brand boosters is that?
Old 07-01-2003, 11:06 AM   #6
Cal69Chevy
Cal69Chevy's Avatar
I'm not sure what booster that is...it was in the truck when I purchased it. I just went out there and couldn't find a single indicator as to the manufacturer or the model on the booster. I've seen several that look similar to it in the catalogs.
One thing to keep in mind, and I should have mentioned this in my first post, I have a 1 ton rear (14 bolt) with drums and in the front I have a dana 44 with disc brakes.
Glad the picture helped...
Ken
Ken's '69 Page
Thread Tools
Display Modes
