Old 06-26-2013, 09:10 AM   #1
Ericluther
Ericluther's Avatar
Is it possible to install bed with no wood in it
Is it possible to install bed with no wood in it? just the frame?
and if so is there anything special I would need to do
Thanks in advance!
Eric
Eric Luther
Anderson Sc
http://67-72chevytrucks.com/vboard/s...d.php?t=567821
Ericluther is offline   Reply With Quote
Old 06-26-2013, 09:57 AM   #2
Blue_Aura
Blue_Aura's Avatar
Re: Is it possible to install bed with no wood in it
Thanks in advance!
Eric
That's how mine is. I've see a lot of our trucks without wood or any floor in the bed. You just have to make sure it is carriage bolted to the frame.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline   Reply With Quote
Old 06-26-2013, 11:26 AM   #3
newbe351
Wouldn't you need spacers? Doesn't the bed sit on the wood with the wood between the bed and the frame, so 3/4" spacers would be needed (I would think).......
newbe351 is offline   Reply With Quote
Old 06-26-2013, 11:42 AM   #4
Blue_Aura
Blue_Aura's Avatar
Actually, I forgot to mention that... Yes, it sits on spacers. Sorry.
Current Vehicles:
Some Past Projects:
Old 06-26-2013, 11:55 AM   #5
K98AL
K98AL's Avatar
I used some big hex nuts that were about 1/2" for spacers. I also used some rubber strap material as a gasket to prevent noise.
K98AL is offline   Reply With Quote
Old 06-26-2013, 06:42 PM   #6
sickboy_1456
I seen a trick little set up a couple days ago on a truck in my area. He had these cool looking alluminum rails that were 3/4 inch taller than the stock cross sills, so the bed would sit right.
sickboy_1456 is offline   Reply With Quote
Old 06-26-2013, 07:04 PM   #7
ChefCy
ChefCy's Avatar
any more pics? was it to clear the c-notch so the bed would appear to look stock?
btw..i do not have a wood floor in my bed as well.
ChefCy is offline   Reply With Quote
Old 06-26-2013, 07:15 PM   #8
sickboy_1456
Unfortunately, those are all the pics I was able to get aside from the truck itself. It only had a pipe notch, so nothing crazy. He basically said he just replaced all of the original cross beams with the alluminum ones that he made. Very simple, but worked perfect.
Old 06-26-2013, 07:38 PM   #9
ChefCy
ChefCy's Avatar
thats a cool idea and a nice truck
Old 06-26-2013, 09:02 PM   #10
Blue_Aura
Blue_Aura's Avatar
That is one nice looking truck!
Current Vehicles:
Some Past Projects:
Old 06-26-2013, 09:10 PM   #11
ianw31
ianw31's Avatar
Do you guys have any pics of how you did your spacers? I need to do this to my bed.
- Ian
1966 C10 Longbed 350/350
ianw31 is offline   Reply With Quote
Old 06-26-2013, 09:39 PM   #12
jayoldschool
Moderator
Spacers need to go up at the front corners of the bed, under the inner bedsides, on top of the frame. I have my bed off/wood out now, I can take pics tomorrow if needed (but it is pretty easy to understand if you look at your truck).
jayoldschool is offline   Reply With Quote
Old 06-26-2013, 09:49 PM   #13
ianw31
ianw31's Avatar
Ok thanks, And I guess I should have asked what is it that you used for spacers?
- Ian
Old 06-26-2013, 10:17 PM   #14
jayoldschool
Moderator
I made new wood boards
Old 06-27-2013, 12:45 AM   #15
gixxer711
No wood in the bed of my 65. I still have the boards running along the bed sides, which you can somewhat see below.
Danny
64 C10 SWB fleet
gixxer711 is offline   Reply With Quote
Old 06-27-2013, 10:15 AM   #16
TJ's Chevy
TJ's Chevy's Avatar
Smile Re: Is it possible to install bed with no wood in it
My truck bed is installed without wood ,and before everyone goes crazy cause they saw wood in there, That is jut a 4x8 cut to size that i laid on there for temporary use around the farm.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-27-2013, 10:52 AM   #17
jayoldschool
Moderator
The two board's in gixxer's pic are exactly what you need.
Old 06-27-2013, 10:57 AM   #18
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
let see some pic or the spacers
Sick5 is offline   Reply With Quote
Old 06-27-2013, 11:18 AM   #19
vin63
It's Better With Nitro
vin63's Avatar
You mean like this?...
I had some 0.75" thick aluminum bar stock laying around and cut that up for spacers. You can see a pair next to the forward gas tank tab mounts. I had that cross sill removed to work on the gas tank plumbing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-27-2013, 01:40 PM   #20
ChefCy
ChefCy's Avatar
here is mine.
http://67-72chevytrucks.com/vboard/a...1&d=1372354721
63 big window lwb bagged and shaved
Thread Tools
Display Modes
