06-28-2013, 02:06 PM | #1 |
327 RPM range
Can anyone tell me the stock red line for a stock 1966 C20 with a 327 and TH400? Where does one put the red marker on the tach? How does the auto's shift points play into this red line? Or do they?
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
06-28-2013, 09:12 PM | #2 |
Re: 327 RPM range
Factory ratings for the high torque 327 with Th-400, 220 HP at 4400 RPM max torque at 320 FT lbs at 2800 RPM, so limit your Redline to 4500 rpm. Thats with a 4-barrel carb, 8.5 compression.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
06-29-2013, 11:22 AM | #3 |
Re: 327 RPM range
I always thought a 327 liked to rev. So my 327 I had in my camaro didn't like 6,000 to 6,250 for shifting? Sure seemed like it loved to rev. I would think for a stock 327 in your truck 5,000 to 5,500 would be no problem if you was needing a little extra go power.
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
06-29-2013, 12:58 PM | #4 |
Re: 327 RPM range
I wonder how the tachs came set from the factory? Surely there must've been a "correct" number.
06-29-2013, 01:20 PM | #5 |
Re: 327 RPM range
This first one is factory installed in our 66 K20 with 292.
This one not sure if its been played with but its in our 64 K10 283 Like to see a 66 327 Tach that's not been out of the cluster ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
06-29-2013, 02:22 PM | #6 | |
Re: 327 RPM range
06-29-2013, 03:12 PM | #7 |
Re: 327 RPM range
Would it be safe to assume that a 327 would have a slightly higher red line than a 283?
Also, I presume the lower red arrow is the bottom of the "power band" or the "working RPM range." In other words, don't work the motor too hard below this point. Of course with the TH400 I suppose all of this is rather moot.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 Last edited by sodly; 07-06-2013 at 12:29 AM. |
06-29-2013, 07:59 PM | #8 |
Re: 327 RPM range
Virtually the same, the 327 had more torque in the lower rpm..!
Thread Tools | |
Display Modes | |
