Old 07-01-2013, 12:47 AM   #1
texman
floor shifter removal
HI HOW DO YOU REMOVE THE FLOOR SHIFTER ON 1972 1/2 TON C 10 IT IS A 4 SPEED I REMOVED THE FLOOR BOOT , BUT DONT SEE HOW TO REMOVE IT LOOKS LIKE IT HAS A HOLLOW PIN THROUGH THE ROUND BALL THAT THE SHIFTER IS CONNECTED TO ANY HELP IS APPRECIATED STEVE
texman is offline   Reply With Quote
Old 07-01-2013, 01:01 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: floor shifter removal
Make sure it's in neutral, then push down on the "ball" and turn counter clockwise a quarter turn and then lift the shifter straight up and out. Hope this makes sense to you
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-01-2013, 03:02 AM   #3
texman
Thinks for the info
Old 07-01-2013, 06:35 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
GM techs used to have a special tool, but I've seen guys do it with a big pair of channel locks. Sometimes I cut 5/8'' wide notch in a short 2x4 stud, about 1-1/2'' deep --push down and twist.
Old 07-01-2013, 08:12 AM   #5
burnin oil
Same premise but the easiest way is to put a large screw driver in the corner of the retainer (where it makes the 90* turn) then smack it downward and counter clockwise at about a 45 degree angle. Pops right out that way. This is the way I have alwasy done them. Use a screwdriver with a good blunt tip.
burnin oil is offline   Reply With Quote
Thread Tools
Display Modes
