Old 07-03-2013, 12:49 PM   #1
GMCGoat
Gas tank filler through flip down plate holder (55-59 truck)
Has anyone seen a rear frame mounted gas tank installed on a 55-59 flare side bed truck where the filler neck comes through a flip down licence plate bracket in the bumper?
Here is the closest I've seen, just not same year. I need to meaure everything up but it looks doable: http://67-72chevytrucks.com/vboard/s...d.php?t=448431
Also one more thing, my truck will get air ride eventually so it would be nice if it didn't get in the way of the truck laying frame (rocker)....but I can always fix that later.
Wish I was at home to measure this up.
GMCGoat is offline   Reply With Quote
Old 07-03-2013, 02:14 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Gas tank filler through flip down plate holder (55-59 truck)
I love the idea and had thought of this myself but always thought the tank would be too visible.
From looking at this one, I think I am right. The tank hangs a little too low to suit me...and I DON'T intend to lower mine severely.
Dan in Pasadena is offline   Reply With Quote
Old 07-03-2013, 02:23 PM   #3
OrrieG
OrrieG's Avatar
Before the current tank I had a 69 chevelle tank in the back as a second tank. I used the chevelle flip down plate, I can't remember if I had to make a bracket for it or if it bolted up to the 59 holes.
OrrieG is offline   Reply With Quote
Old 07-03-2013, 06:12 PM   #4
Dan in Pasadena
Orrie,
Why did you change from what you had?
I really would love to use the flip down license rather than a through-the-bed floor setup but I just don't want it to show.
Also, I intend to use the bolt on U-Haul receiver hitch #75133 that I THINK Rudy? (Rude Dude) posted will fit.
Old 07-03-2013, 08:55 PM   #5
GMCGoat
If I go out and buy a new tank, sending unit, filler neck etc... for in cab...will it smell....I don't reallly mind it behind the seat, but I hate the smell.
It's leaking pretty bad now...it is visible. before it was only when i filled up all the way.
Old 07-03-2013, 10:21 PM   #6
G&R's57GMC
G&R's57GMC's Avatar
Originally Posted by Dan in Pasadena View Post
Orrie,
I really .......
Hay Dan, That was me. I would call U-Haul and make sure its still available
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 07-03-2013, 10:56 PM   #7
Dan in Pasadena
Oh, ok...sorry. I've also read that the receiver for a Chevy Venture/Uplander (now THERE'S a dork name for 'ya!) is a straight bolt up. eBay has them for $108. How much do you think the U-Haul one runs?
Old 07-03-2013, 11:18 PM   #8
OrrieG
OrrieG's Avatar
Orrie,
Old tank rusted out, and when that tank was more than 2/3 full I could not go up hill, the fill tube was too flat. Strategy was to run it low first on the way in, then switch to the original tank behind the seat, so it would not be an issue off road. I always found myself driving out of my way to get gas to get home because the original did not hold enough. I used gerry cans for a while but got tired of the gas smell in the camper. The tank also hung down lower than the aluminum one I have (rock/log hazard) and the neck would have interfered with the receiver hitch. If most of your use is going to be in relatively flat country (not San Francisco) than out the back is fine.
I got my receiver for $3 (three not a typo) dollars, it is for Chevy (and maybe other) trucks with 34" wide frames. It bolted to the bottom, but I modified it to mount to the side of the frame because the gas tank bolted to the bottom. There are lots of them used around here usually in the $40-60 range. Mine was cheap because the guy had just bought the house and just wanted scrap value out of it and some other stuff that was left in the back yard.
Old 07-03-2013, 11:23 PM   #9
GMCGoat
Update:
going to sleep on it but first choice is
http://www.boydwelding.com/shop/inde...inum-tank.html
Second choice is something like this:
http://www.mooneyesusa.com/shop/prod...roducts_id=549
Old 07-04-2013, 12:01 AM   #10
Dan in Pasadena
Both of those ARE nice. The mooneyes is waay pricey! Too rich for my budget, plu I wouldn't want it showing in my bed.
Someone JUST posted a link in another thread to a deal for a Mustang type tank but that will accept a generic GM/Universal sending unit with the 5 bolts instead of the Ford collet mount. I THINK it was only $219. Also, member ChuckDriver used a universal underbed tank from Tanks, Inc that was in the low $200 range too.
Old 07-04-2013, 06:47 AM   #11
GMCGoat
I agree that the Mooneyes was $$$ but it was just an example. This seems more reasonable if I went that route:
http://www.ebay.ca/itm/270823385147?...84.m1438.l2649
I think I'm going with the Boyd Welding tank though. I think it will be perfect for now and then, when I finallly do the air ride, I can move the brackets lower in order to push the tank up when I raise the bed floor to accomodate the step notch. All said and done, I'll be looking at $500.
and the best part is, I will see no performance gain out of it...haha well, aside from no grogginess from inhaling gas fumes.
Old 07-04-2013, 06:54 AM   #12
GMCGoat
One more question:
The Boyd Welding tank only provides an option for a sending unit with a 0-90 ohm sending unit, but it is my understanding that I need a 0-30 ohm sending unit. I've inquired with the vendor but thought I'd ask for advice here.
Should I just buy this 0-30 from Brothers?
http://www.brotherstrucks.com/prodin...number=ATK59SU
Thanks for all your help.
Old 07-04-2013, 09:59 AM   #13
mknittle
mknittle's Avatar
this one?
http://www.tanksinc.com/index.cfm/pa...rod/prd129.htm
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-04-2013, 10:07 AM   #14
mknittle
mknittle's Avatar
I don't like the looks of the Boyd welding tank hangers. they look like they could crack over time. JMHO
Mark
My GMC build.
Old 07-04-2013, 10:18 AM   #15
roger55
roger55's Avatar
Thanks to Speedbump, I used this tank from Tanks, Inc.
http://www.tanksinc.com/index.cfm/pa...prod/prd73.htm
Here's a thread where I detail how I mounted it and routed the fill hose: (Jump to post #54 and the rest of my posts thru the end of the thread).
http://67-72chevytrucks.com/vboard/s...6&goto=newpost
roger55 is offline   Reply With Quote
Old 07-04-2013, 02:19 PM   #16
oldcouple
oldcouple's Avatar
It works with a rear roll pan. Someday I will add the bumper, will need to slot the pan to do so..
Retired and too busy to work.
oldcouple is offline   Reply With Quote
gas tank; relocation
Thread Tools
Display Modes
